63 FI Idler pulley - NCRS Discussion Boards
63 FI Idler pulley
  • Todd L.
    • November 25, 2020
    • 294
    63 FI Idler pulley
    I have the original idler pulley from my 63 Fuelie that needs restored. Does anyone know if these can be taken apart and restored, and if so, who does this? I would prefer to restore this one if it makes financial sense, but I know I can buy a repro from the big box retailers if not.
    Todd
  • Bob W.
    • December 1, 1977
    • 802
    Re: 63 FI Idler pulley
    Tom, In Zip Corvettes new C1 catalog they have a replacement bearing # m-4273 for $84.99.The bearing will work for 62 and up.
    Bob
      • 43247
      Todd
      Todd------
      Very easy to rebuild. You need two things: a hydraulic press to remove the bearing from the bracket and pulley AND a bearing assembly last available from GM under GM #908076. It's GM-discontinued but should be otherwise available.
      By the way, the pulley assembly was installed at St. Louis so I do not understand why the bracket on this one is painted engine orange. As I recall, the bracket should be semi-gloss black and the pulley natural steel or zinc plated.
      • Todd L.
        • November 25, 2020
        • 294
        Thanks Joe,
        I believe this was painted by the previous owner, not the factory.
        • Todd L.
          • November 25, 2020
          • 294
          Thanks for the part # Bob
            • 43247
            Thanks Joe,
            Todd------
            If you do rebuild it make sure that you measure the relevant dimensions PRIOR to disassembling so that you can install the bearing assembly and pulley correctly.
            • Todd L.
              • November 25, 2020
              • 294
              Great suggestion, thanks.
              • Bob W.
                • December 1, 1977
                • 802
                Todd, Let me know how you make out.
                Bob
                • Todd L.
                  • November 25, 2020
                  • 294
                  Well, I got the bearing out of the bracket, but can't figure out how to get under the bearing to hold it so I can press the shaft out. Any suggestions?
                  • Bob W.
                    • December 1, 1977
                    • 802
                    Todd, I think you should have removed the pulley first then the bearing. So turn the pulley upside down support with something like a deep well socket and press the bearing out. By the way sorry about calling you Tom I don't know where that came from !!!
                    • Paul Y.
                      • September 30, 1982
                      • 570
                      I had a water pump rebuilder in Denver that got a bearing for me and installed it on my idler pulley and it has worked flawlessly for many years. I agree with Joe L about the pulley being natural and the assembly being semi-gloss black. Paul
                      It's a good life!
                      • John D.
                        • December 1, 1979
                        • 5507
                        Todd, Look in the 7th judging manual for info on the finish of this part. Page 150.
                        As I well know from restoring our original fuel injection your car is a border line case between early and the next level. Caught in the middle.
                        Lot of finish details in the idle assembly section of the manual.
                        In the photo your pulley is cadmium or maybe zinc. That's correct for your car. Later '63 has a black phosphate finish. Listen to what Joe Lucia said. Very important or your fan belt will be having alignment issues. John D.
                        • Bob W.
                          • December 1, 1977
                          • 802
                          Todd, Have you made any progress on your idler pulley rebuild?
                          • Todd L.
                            • November 25, 2020
                            • 294
                            Hello Bob,
                            I was able to get everything apart, but not without destroying the bearing completely. The pulley and bracket are good, and I ordered a replacement bearing assembly from ZIP. Once that comes in, I will get everything back together and send an updated picture.
                            Todd
                            • Bob W.
                              • December 1, 1977
                              • 802
                              Todd, Thanks for the reply. When you get the bearing check to see if there is any part numbers stamped on it.
                              Bob
