3461S Carter AFB Restorer? - NCRS Discussion Boards
    • 11668
    I need to have a Carter AFB restored for a 1963 convertible that is in the shop.
    Who is the current recommended restorer for these carbs?
    Chuck Smith?
    Thanks for any leads you may have.
    Patrick
  • Daniel S.
    • January 14, 2011
    • 309
    Re: 3461S Carter AFB Restorer?
    Patrick, I've used Eric Jackson with great results for years... also used Tom Zeeman and Phil in NJ over the years. Any three of these guys are top notch.
    Dan
      • 11668
      I thought that Eric and Tom only did Holleys?
      • Gary B.
        • February 1, 1997
        • 7053
        Patrick,
        Eric also restores Carter AFBs. See towards the bottom of his webpage:
        Gary
        • Douglas C.
          • August 31, 1990
          • 384
          I've used Phil at Custom Rebuilt Carburetors in Jersey for many years. Exceptional quality on any type carb, plus an honest fair priced guy who stands behind his work. Doug
          • Kenneth F.
            • September 30, 1988
            • 284
            Eric Jackson was great to work with for a 1964 Carter AFB. Eric ran my carburetor on a test engine. It was ready to run on my engine with no adustments needed.
            Ken
              • 11668
              Ken
              I suspect we will use him, as I've had a couple of issues with Phil's place several year ago.
              I have yet to hear anything bad about Eric.
              • Don L.
                • August 31, 2005
                • 1005
                Hi Patrick and Merry Christmas.
                As I think you know, I’ve relocated to Lake Norman North Carolina and have added a ‘63 Biscayne 409/425 to my stable. I had a guy here rebuild the primary (Carter) carb. He’s a former NASCAR team member and then NASCAR official. He came well-recommended. When I tell people here I had my carb redone, most say they hope I used Mike Butler. I did. He knows all carbs and can do as little as adjustments to complete restorations, including re-plating. PM me if you want his contact info.
                Regards
                Don Lowe
                NCRS #44382
                Carolinas Chapter
                • Dave S.
                  • August 31, 1992
                  • 2926
                  Patrick,
                  Merry Christmas to you and your family.
                  Chris Carb shop in Dayton, Ohio did my 3461 and has done many others for me.
                  Great guy who tests on a test motor
