Head lamp headlight motor grease - NCRS Discussion Boards
  • David H.
    • November 11, 2009
    • 777
    What grease would you use when rebuilding the gear side of the C2 headlight motors?
  • Gary S.
    • July 31, 1992
    • 1628
    Re: Head lamp headlight motor grease
    I've used white lithium although some here say it hardens in a couple of decades. I've also used synthetic wheel bearing grease, same car different side, and see no difference in operation
    • Alan D.
      • January 1, 2005
      • 2032
      Just use a good synthetic grease, the white lithium does harden however it takes a long time.
      • Frank D.
        • December 27, 2007
        • 2703
        I use marine grade wheel bearing grease.... The kind recommended for boat trailers...
        • David H.
          • November 11, 2009
          • 777
          • James W.
            • December 1, 1990
            • 2647
            The openings are correct. I've never seen one that wasn't this way. Based on the gearbox location it's hard to get water in them.
            James
            Originally posted by David Hurd (51036)
            Thanks very much for your thoughts on this. I decided on Lucas White lithium.
            I trust Lucas products.
            I have another question about this.
            I noticed the motors have openings in the cases that are open to the elements that allow moisture etc. to enter the gear box.
            This can’t be correct can it?
            What am I missing?
            See picture.
            • Frank D.
              • December 27, 2007
              • 2703
              I agree, I wouldn't worry about those openings....the car would have to be nearly
              submerged for water to migrate into the headlight motor casing...
              I've neve opened up a motor and found one water contaminated.
              • Gary C.
                Administrator
                • October 1, 1982
                • 17606
                CRC3331 https://www.crcindustries.com/produc...-10-wt-oz.html highly recommended to lube headlight motors
                Gary
                NCRS Texas Chapter
                https://www.ncrstexas.org/
                • Enzo C.
                  • January 12, 2012
                  • 534
                  Who drives there C2 in the rain anyways ...
                  Enzo Colosimo
                  Ncrs Ontario Chapter Chairman 🇨🇦
                  ENZ-Z06/67
                  • Jim L.
                    • September 30, 1979
                    • 1806
                    Well, I have done it.
                    When bringing my Dad's '54 and '63 to CA from GA, we got caught in a downpour while passing through Salt Lake City.
                    While I wouldn't enjoy getting caught in the rain again in the '54, if it happened while in the '63, it wouldn't be a big deal.
                    • John D.
                      • June 30, 1991
                      • 874
                      Just rebuilt the motors in my 67 and the white grease (lubriplate ?) was like mud. Considering it took 55 years for that to happen the synthetic wheel bearing grease I used will long outlast me.
                      Another lesson I learned is indexing the slot in the motor with the headlamp housing in the closed position makes installation a lot less tricky.
                      • Frank D.
                        • December 27, 2007
                        • 2703
                        If you live in Florida an unexpected monsoon can sweep in with driving rain and be gone again in 45 minutes with a return to hot, steamy weather.
                        I've driven both my 61 and 63 in such conditions and the "baby breath" defrosters on the 61 are worthless and the wipers not much better.
