'65 Differential to Crossmember Mounting hardware per the AIM??? - NCRS Discussion Boards
  • James W.
    • December 1, 1990
    • 2673
    So i have been reviewing the '65 AIM before I reinstall the crossmember to the differential. The AIM calls for lock washers to accompany the 4 mounting bolts. My car has heavy flat washers and from the looks of the washer outline/footprint on the crossmember surface it has always had the heavy flat washers. Can I assume this was a factory assembly error? One of the bolts and washers is pictured with the AIM page.
    James
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11364
    Re: '65 Differential to Crossmember Mounting hardware per the AIM???
    I've seen both lock or flat. I like thick flat and a dab of blue Loctite myself.
    Rich
    • Gary B.
      • February 1, 1997
      • 7070
      • Page C.
        • February 1, 1979
        • 802
        The following form GM Engineering Standards on #446212
        Type A flat washer with zinc finish
        ID= .438 basic .453 max .433 min
        OD= .875 basic .905 max .868 min
        Thickness= .083 basic .104 max .064 min
        Hope this helps
        Page
        • James W.
          • December 1, 1990
          • 2673
          Thanks Rich. That's exactly how it will go back together.
          James
          Rich
