'New' '66 joins fleet... - NCRS Discussion Boards
    • 11692
    #31
    Re: 'New' '66 joins fleet...
    Originally posted by Michael Garver (49693)
    The plug wires I took off said “LUCAS” on the rubber under the mesh grounding sleeves. The “Prince of Darkness” should not be on a non-British vehicle, so I’ve relegated him to the trash bin…
    If those might be original mesh sleeves, you'll want to keep them and just throw away the wire portions.
    • Michael G.
      • November 12, 2008
      • 2158
      #32
      Mike
      1965 Black Ext / Silver Int. Coupe, L84 Duntov, French Lick, 2023 - Triple Diamond
      1965 Red Ext / White & Red Int. Conv. - 327/250 AC Regional Top Flight.
        • 11692
        #33
        They may well be original, were Lucas plug wires used in ‘66?
        Not on Corvettes.
        I'm not sure I'd use them on my Austin-Healey.
        • Michael G.
          • November 12, 2008
          • 2158
          #34
          Not a big deal on a Healey, you don't expect them to run anyway
          I not sure I'd go to all the trouble of threading a Lucas wire into the original sleeve, though....The boots just disintegrated & I'm amazed to see the black corrosion on the distributor end's brass connector...
          Mike
          • Michael G.
            • November 12, 2008
            • 2158
            #35
            Mike
            • Michael J.
              • January 27, 2009
              • 7167
              #36
              The first thing I would check is the upper A arm bolts. They tend to work loose on BBs more frequently than SBs. I have had them work loose on my '66 L36, even lost one in the driveway after a cruise. That's a safety issue of high importance. How easily does it start after sitting or when it is hot? I would also check for any oil leaks around the top of the oil filter canister, over time they can also become weak. Good luck and have fun, my '66 L36 is my favorite driver, less drama than the fuelies.
              • Michael G.
                • November 12, 2008
                • 2158
                #37
                Mike
                • Michael G.
                  • November 12, 2008
                  • 2158
                  #38
                  Mike
                  • Larry E.
                    • 1698
                    #39
                    Mike: Just a few items I do with my 66 Red Coupe for the Winter. Put in straight Av Gas in tank to be safe for
                    gas deterioration purposes. I take my battery out and put a small trickle charger on it. These two items have
                    never failed me. Good Luck>Larry
                    Larry
                    LT1 in a 1LE -- One of 134
                    • Michael G.
                      • November 12, 2008
                      • 2158
                      #40
                      Mike
                      • Larry E.
                        • 1698
                        #41
                        Mike: Looks like your in good shape with my suggestions. AFA the Chrome Vs. Chevy Orange if you search the board I believe
                        it was Duntov's decision to this. Reason IIRC was the Orange made the B/B stand out better under the hood. Too each his own
                        on this but I prefer the Chevy Orange. I had a 68 L68 which chrome factory covers and it just did not come across as good as
                        the orange but that's just me. Thanks>Larry
                        Larry
                        • Michael G.
                          • November 12, 2008
                          • 2158
                          #42
                          Mike
                          • Michael G.
                            • November 12, 2008
                            • 2158
                            #43
                            Mike
                            • Ronald L.
                              • October 18, 2009
                              • 3248
                              #44
                              When did he make that post? This year?
                              Last year?
                              • Michael G.
                                • November 12, 2008
                                • 2158
                                #45
                                Looks like August 26th of 2021
                                Mike
