1970 proper glue for rubber seals ? - NCRS Discussion Boards
  • Bob B.
    • January 30, 2007
    • 524
    What is the current best glue to use installing rubber door jam seals ? 1970 rear convertible deck seal ?
    Yellowish brown if I remember right ?
    Thanks Bob
    • January 31, 1988
    • 43196
    Re: 1970 proper gue for rubber seals ?
    Thanks Bob
    Bob------
    3M Yellow Super Weatherstrip Cement. The factory-applied weatherstrip cement was originally yellow but oxidized to brownish yellow over time.
    • Bob B.
      • January 30, 2007
      • 524
      JOE THANK YOU
      Bob
      • Bob B.
        • January 30, 2007
        • 524
        Joe, I seem to remember that the factory used a brush with a can of the 3m yellow cement, 3M offers the 5 oz tube of yellow cement for about $15,
        but also offers a yellow Neoprene 10 cement in a quart can, so you can brush it on. Am I overthinking this or is my memory shot ?
        Thanks Bob
        • Gary B.
          • January 31, 1997
          • 6992
          • Mike E.
            • February 28, 1975
            • 5135
              • January 31, 1988
              • 43196
              Thanks Bob
              Bob------
              The original adhesive was neoprene solvent cement and I believe it was applied with a brush. However, I think a quart can is going to be a lot more than you need.
                • May 31, 1974
                • 8371
                i agree with mike ernst. just be sure to wipe the new weatherstrips with lacquer thinner to remove any release agents. the cement adheres way better to clean rubber. mike
                • Bob B.
                  • January 30, 2007
                  • 524
                  Thank you, I am going to give the DAP a try, can always go back to 3m if it doesnt work out. My car shows the brush on was done to the UAW quality standard of the 70's.
                  Bob
                  • Gary B.
                    • January 31, 1997
                    • 6992
                    Gary
