'63 Upper hiperf 3827368 repop hose too short - NCRS Discussion Boards
  • Mike L.
    • January 1, 1986
    • 312
    Re: '63 Upper hiperf 3827368 repop hose too short
    None of my original hoses have a blue stripe, all have white letters and a white stripe. GM used a couple of suppliers for there rubber products. But back to my original question what about hose #3777482 (white letters with GM AU printed. Like I stated before GM parts book says 63-65 top hose FI, says nothing about it for a 62 FI car.
    • Lenny K.
      • June 2, 2008
      • 53
      There is some interesting Blue/White stripe folklore in this link... Lenny
      https://www.forums.ncrs.org/showthre...ght=upper+hose
      • John D.
        • December 1, 1979
        • 5507
        #18
        My original top water hose has a thin blue stripe.
        • Lenny K.
          • June 2, 2008
          • 53
          #19
          Thanks John.... regardless of stripe or markings, it looks like www.docrebuild.com is the only reliable source for a longer upper hiperf hose with "correct" stamp/stripe at this time. I am working with him to buy TWO..... one spare.... he will have to create them from genuine GM hose materials and it does seem that, for whatever reason, Paragon reverted to a ~2" shorter 3827368 repop hose vs. producing the longer one and letting buyers shorten it to fit their need, if necessary..... go figure.... smile... Lenny
          • Lenny K.
            • June 2, 2008
            • 53
            #20
            www.docrebuild.com has made some of the "genuine" 3827368 19" Hoses available.... I just ordered two of them.... smile.... Lenny
            • Leif A.
              • August 31, 1997
              • 3632
              #21
              I'm sure you will pleased with his product...he's never disappointed me. Post up a picture when you get them.
              Leif
              • Al H.
                Infrequent User
                • June 30, 1986
                • 3
                #22
                Hi, I changed the coolant in my 1965 327 365 HP with original radiator and intake and have had the same problem with short Paragon hoses from 3 different vendors. Did you receive your hoses? If so I need to contact Dr. Rebuild. Their web site is confusing as it appears the business may be closed. i called and got an answering machine. Thanks, Al
                • Al H.
                  Infrequent User
                  • June 30, 1986
                  • 3
                  #23
                  • Leif A.
                    • August 31, 1997
                    • 3632
                    #24
                    He's open for business. Best to order online vs trying to call.
                    Leif
                    • Lenny K.
                      • June 2, 2008
                      • 53
                      #25
                      Yes I did get TWO of them after they became available..... hopefully he is not out of business but who knows these days.... smile... Lenny
                      PS.... looks to me like the site is still up..... here is the part you need....
                      1963-1965 Corvette Upper Radiator Hose Genuine GM with Blue stripe 3827368 (docrebuild.com)
                      • Dan H.
                        • July 31, 1977
                        • 1369
                        #26
                        Have you tried to install one yet? Good luck.
                        1964 Red FI Coupe, DUNTOV '09
                          • 11644
                          #27
                          They don't usually open until 11:00.
                          I was emailing with him over the last week, and talked to Deb this afternoon.
                          • Dan H.
                            • July 31, 1977
                            • 1369
                            #28
                            Lenny, suggest you compare this hose and its configuration to original, it is different from GM originals, had one, wouldn't fit, too long and slightly different. Docs items are usually spot on, check it out.
                            Dan
