1965 AOS vs. STL Body Build Month Letter Start Date - NCRS Discussion Boards
  • James W.
    • December 1, 1990
    • 2655
    Did the AO Smith body build date start begin in August or September?
    James
  • Larry M.
    • January 1, 1992
    • 2688
    Re: 1965 AOS vs. STL Body Build Month Letter Start Date
    August for model year 1965. St Louis bodies were the same.......August.
    However, I do not know the August numbers from each facility for convertibles and coupes.
    Larry
    • James W.
      • December 1, 1990
      • 2655
      Larry,
      Thanks for the info. I didn't think that one body assembly plant would start a month later (September) than the other.
      James
      Larry
      • Jack M.
        • March 1, 1991
        • 1153
        FYI- When the last week of the month spans two different months, then the difference in start dates can be minimal... it just seems months apart. For example: In 1966, I've seen an A.O. Smith Trim Tags starting on 8-30-65 (A30 - Coupe Body #3)... while St Louis started approx 9-3-65 (A03 - Conv Body #16). Itz the SAME physical week... but encompasses two different months (if I explained that korrectly).
