a very difficult fix 1965 - NCRS Discussion Boards
  • Michael G.
    • November 12, 2008
    • 2157
    Re: a very difficult fix 1965
    Not sure why we’re still talking about using JB Weld, it isn’t necessary. If there’s extra depth in the hole, its been put there by a drill size that is perfect for forming threads in. As such, just ignore the stripped threads in the upper part of current hole and run a bottoming tap until it stops. You will then have formed about three new turns of thread in the tap-drilled hole that’s already there. If you then then use a longer screw, one that doesn’t bottom in the hole, that’ll have plenty of strength for the current assembly torque and they are threads formed in real cast iron, not JB Weld of questionable strength.
    Mike
    1965 Black Ext / Silver Int. Coupe, L84 Duntov, French Lick, 2023 - Triple Diamond
    1965 Red Ext / White & Red Int. Conv. - 327/250 AC Regional Top Flight.
    • Mark G.
      • January 31, 2007
      • 177
      Loctite does sell a thread repair kit. I've personally have never used it. https://www.napaonline.com/en/p/NCB28654
        • 43247
        #18
        Mark------
        I tried it once with absolutely zero success.
        • Bruce W.
          • June 30, 1997
          • 360
          #19
          Hey guys,
          Thanks for all your help. JB weld didn't hold up. After much thought and being the perfectionist that I am I have decided to pull the head and send it out to be fixed. Temporary fixes may be ok in some situations but my experience is they come back to bite you. Sometimes I wonder why I choose this hobby? Thanks again
          Bruce
          • Tony R.
            • April 19, 2017
            • 201
            #20
            Sometimes we need to remind ourselves that we do this for FUN. 🙂
            • Domenic T.
              • January 29, 2010
              • 2452
              #21
              Can you tap it for a larger bolt, then screw the bolt in and cut it flush. hen drill and tap it. It can also be made on a lathe and installed. larger bolt has to be tight and with locktite or JB.
              Dom
                • 43247
                #22
                Originally posted by Bruce Wilcox (29338)
                Hey guys,
                Bruce
                Bruce------
                I'm surprised that the JB Weld did not work for you. I've used it for much more difficult situations than the valve cover bolt.
                In any event, I really don't think you need to go as far as pulling the head. The longer bolt solution that Michael offered will almost certainly work.
