Radiator expansion tank hose - '75 L-48 - NCRS Discussion Boards
  • Lynn S.
    • May 5, 2016
    • 105
    Here's an easy one. Does the hose from the radiator to the expansion tank have clamps at both ends that are the same or as the TIMJG says a different clamp is used on the radiator end and a spring clamp on the bottle end. If possible, please include a picture with your reply specific to 1975. Thanks in advance. Lynn
    Lynn Skipper 62393
    1995 LT-1 Polo Green conv. w/ Beige/Beige, Chapter Top Flight
    2018 LT-1 GS conv w/ Kalahari/Black, Heritage pkg, 2LE, 8sp w/ paddles
    1975 L-48 Steel Blue conv, w/ Med Saddle/Med Saddle, 4 spd, C-60 current project.
  • Tom R.
    • June 30, 1993
    • 4100
    Re: Radiator expansion tank hose - '75 L-48
    See if this helps! This is from the "soon-to-be-published" 3rd edition.
    A small diameter hose connects the coolant recovery tank to the radiator using a single black spring-clamp is at the cap end and a green spring-clamp is at the radiator. (See Fig. M 19.15)
    The black hose has a yellow stripe with EVAP. (Fig. M 19.15) Some hoses include numbers, such as D10022 in between stripes while others are seen with a solid yellow stripe. Different series of numbers have been seen and could include a date code but with no regular pattern.
    What are you doing about the water shut-off valve?
    Tom Russo
    78 SA NCRS 5 Star Bowtie
    78 Pace Car L82 M21
    00 MY/TR/Conv
    • Robert S.
      Infrequent User
      • August 4, 2012
      • 11
      • Lynn S.
        • May 5, 2016
        • 105
        As always, Thanks Tom. Lynn
        Lynn Skipper 62393
        • Lynn S.
          • May 5, 2016
          • 105
          Thanks Robert. Lynn
          Lynn Skipper 62393
          • Tom R.
            • June 30, 1993
            • 4100
            Tom Russo
            78 Pace Car L82 M21
            00 MY/TR/Conv
            • Lynn S.
              • May 5, 2016
              • 105
              That part of the car was still attached to the car and without the valve. We are going without the valve and hope it is correct for the judging team in February. See you in Lakeland.
              Lynn Skipper 62393
              • Tom R.
                • June 30, 1993
                • 4100
                should be a good exercise and test whether all the judges have read the 3rd edition manual. They'll be in for a shock if they depend on the 2nd edition.
                Tom Russo
                78 Pace Car L82 M21
                00 MY/TR/Conv
                • Lynn S.
                  • May 5, 2016
                  • 105
                  Thanks for all of your help Tom. I followed your directions and got into the forum and started reading. Extremely informative.
                  Lynn
                  Lynn Skipper 62393
