1969 Steering Relay Rod (w/o PS) - NCRS Discussion Boards
  • Frank F.
    Infrequent User
    • June 30, 1996
    • 3
    I recently purchased a 1969 SB from the original owner. Body is off and I'm working on the chassis. Trying to locate a shop drawing, or similar, to verify the manual steering relay rod (3952701) is dimensionally "correct" and not bend/deformed/twisted.
    Thanks.
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11345
    Re: 1969 Steering Relay Rod (w/o PS)
    Frank,
    As that blueprint may be tough to find....
    Post some photos of yours with some measurements along side a straightedge at fixed points.
    Some here with the same rod may be able to get some references for you.
    Rich
    • Frank F.
      Infrequent User
      • June 30, 1996
      • 3
      Rich,
      I've attached a couple of photos. First photo; I circled the center of the straight edge, looks slightly bent? Second photo; end of rod near idler. Thanks.
        • 43259
        Originally posted by Frank Ferrano (27842)
        Rich,
        [ATTACH=CONFIG]108289[/ATTACH] [ATTACH=CONFIG]108288[/ATTACH]
        Frank------
        I think I have 2, one NOS and one used (removed from my 1969 when I converted to power steering) [none for sale]. However, I'm in Italy right now and won't be home for several weeks. When I get home I'll be able to photograph and measure one.
        By the way, the 1969 and later relay rods, both manual and P/S, are different from earlier as they are 7/8" OD versus 3/4" for earlier.
        • Richard M.
          Super Moderator
          • August 31, 1988
          • 11345
          Frank until Joe returns here are several from a '67 for reference. Even though it's a smaller diameter rod as Joe mentions it may help compare.
          I think you may be right that yours may have a bend.
          Rich
