207 coil - NCRS Discussion Boards
207 coil
  • Bruce W.
    • June 30, 1997
    • 360
    207 coil
    Hey guys,
    Need a little help here. I have two 207 coils . One has 207 imprinted at the top of the coil and the other at the bottom of the coil. The judging manuel doesn't state which one is correct? One I think is a repro? which one is correct?
    Bruce
  • Bob R.
    • June 30, 2002
    • 1595
    Re: 207 coil
    I am not familiar with the 207 coil however with the 091 coil the originals are embossed near the bottom and the reproduction is near the top. I would guess the 207 is the same.
    • Alan D.
      • January 1, 2005
      • 2053
      Re: 207 coil
      see: https://www.forums.ncrs.org/showthre...Coil-Embossing
      Also check with Dave Fiedler
      The 207 coil I have is embossed on the can 207, under that 12V, about 3/4" from bottom
      Only Delco Remy on top (Coil I look at has magnetic studs - thanks Mike)
      • Mike M.
        • May 31, 1974
        • 8408
        Re: 207 coil
        original deco coils have magnetic studs, the chines junk has stainless studs which dont hold a magnet. mike
        • Mark S.
          • July 31, 1983
          • 664
          Re: 207 coil
          Chines means Chinese?
          • Mike M.
            • May 31, 1974
            • 8408
            Re: 207 coil
            yes, mike
            • Bruce W.
              • June 30, 1997
              • 360
              Re: 207 coil
              thanks Mike, an easy check.
              Bruce
              • Rick B.
                • April 11, 2010
                • 140
                Re: 207 coil
                Bruce, are the case diameters the same between the two?
                • Bruce W.
                  • June 30, 1997
                  • 360
                  Re: 207 coil
                  Rick, yes they are the same size. But the coil I bought has non magnetic posts. According to Mike this isn't correct. Also the bottom of the coil is flat with no indentions. So I guess I got my answer.
                  Bruce
                  • Rick B.
                    • April 11, 2010
                    • 140
                    Re: 207 coil
                    Yes sir, also another sign fyi is thickness, as many if not all of the chinese repros are fatter in diameter. Glad you got what you needed.
                    • Domenic T.
                      • January 29, 2010
                      • 2452
                      Re: 207 coil
                      I'm about to start my 67 BB 435 after 5 years of getting booged from A6 compressors and the shooting of my son who is doing well from less than 1% chance of living.
                      I went to points back in the 70's due to unreliability of electronic devices. I need to buy a coil that is most correct. I have many on the shelf , but am open to a new one. Any suggestions?
                      Dom
                      • Dan D.
                        • November 5, 2008
                        • 1323
                        Re: 207 coil
                        Dom, glad your son is doing well. I have been wondering, but I would not ask.
                        -Dan-
                        • Domenic T.
                          • January 29, 2010
                          • 2452
                          Re: 207 coil
                          Dan,
                          Thanks for all the prayers from the forum. he is different now and can't work because of the massive stroke when they removed part of his brain, but he is with us and still knows cars. Just can't work on them. Walks, but can't use his left side.
                          He beat the less than 1% chance of survival. He will hear that 67 roar.
                          Dom
                          • John D.
                            • December 1, 1979
                            • 5507
                            Re: 207 coil
                            Originally posted by Bruce Wilcox (29338)
                            Hey guys,
                            Bruce
                            Bruce, I did not read all the replies. Put a magnet on the two threaded studs. Repro studs are not magnetic. John
