1975 L-48 engine Valve cover label - NCRS Discussion Boards
  • Lynn S.
    • May 5, 2016
    • 105
    Can anyone provide a photo of the YELLOW TAG with number 330534 attached to the Passenger side valve cover and in the vicinity of the crankcase vent intake. The TIMJG on page 59 top paragraph states: " The passenger's side cover has a crankcase vent intake and a YELLOW TAG with black numbers reading 330534 with a black grommet, black metal tube and black hose extending to the air cleaner base."
    Thanks in advance for your help on this request.
    Lynn
    Lynn Skipper 62393
    1995 LT-1 Polo Green conv. w/ Beige/Beige, Chapter Top Flight
    2018 LT-1 GS conv w/ Kalahari/Black, Heritage pkg, 2LE, 8sp w/ paddles
    1975 L-48 Steel Blue conv, w/ Med Saddle/Med Saddle, 4 spd, C-60 current project.
    • 11668
    Re: 1975 L-48 engine Valve cover label
    It's on the hose connection, not the valve cover. Assuming you're using the old JG, wait for the new one before making many/any changes to your car.
    You know where you can get this sticker.
    • Jimmy P.
      • June 24, 2014
      • 1696
      Lynn
      Hi again Lynn,
      That information in the "outdated second edition" isn't correct. It was probably just a carryover from the 73-74 TIM&JG. Part number 330534 is for the 73-74 SB crankcase tube. The tube is different for '75 even though some vendor catalogs list it for 73-75 350's. There is also a different tube for the 73-74 454 engines and it is 330523. The air cleaner base on the '75 is a tad different ( in the rear) than the 73-74 because of the HEI distributor. Thus the need for a different shaped Vent tube. If I'm not mistaken I believe the GM part number for the 75-81 tube is 3970072. Since you asked for a photo here are photos from a 73-350 and a 74 -LS4 that show original yellow part number tags on the vent tubes. I've included a nice photo of a '75 Vent tube for you to note the difference in shapes. Hope this helps clarify.
      Please heed Patrick's advice and try to wait for the new revision before making changes to your car!
      Jimmy
      1973 Convertible
      L48,M20,N40
      Mille Miglia Red/Oxblood
      • Lynn S.
        • May 5, 2016
        • 105
        Lynn Skipper 62393
