Rebuilt 1963-360HP engine - NCRS Discussion Boards
  • Jerry C.
    • November 1, 1995
    • 741
    This seems to change yearly but what is the best oil and break in additive to use? Stock engine with flat top pistons. Thanks in advance.
    • 15706
    Re: Rebuilt 1963-360HP engine
    Where did you get the idea that it changes yearly?
    • Jerry C.
      • November 1, 1995
      • 741
      Seems like the manufactures change content, just trying to keep up with the best products to use.
        • 15706
        CK-4 replaced CJ-4 a few years ago, and some formulations changed slightly, but the tests didn't so CK-4 is fully "backward compatible" with earlier specs.
        So 15W-40 CK-4 is the best value for an oil with high anti-wear additive content for sliding surface valve train engines. If GM still sells EOS add a pint.
        If the cam lobes and lifters were treated to a moly break-in grease, change the filter after the 20-30 minute breakin at 2000-2500 because the solids in the moly great can clog the filter. So just change the filter, top off the oil and run it at least 500-1000 miles.
        Thereafter just use 15W-40 CK-4, and no supplemental additives are necessary.
