72 LT1 renovation question re: exhaust clamps - NCRS Discussion Boards
  • Fred H.
    • December 4, 2019
    • 311
    Need help identifying the correct style 2 2/2 " exhaust clamp for our 72 LT1
    Fred Hickey
    Care taker of Top Flight 72 LT1 C60 Convertible #26756
    • 11643
    Re: 72 LT1 renovation question re: exhaust clamps
    Which location - middle connection, or exhaust tip clamp?
    • Fred H.
      • December 4, 2019
      • 311
      Hi Patrick, My original question is regarding the middle connection. However I would like your conformation that the exhaust tip clamp in the attached photo is correctE tip clamp a.jpg
      Fred Hickey
        • 15599
        Originally posted by Fred Hickey (66564)
        Hi Patrick, My original question is regarding the middle connection. However I would like your conformation that the exhaust tip clamp in the attached photo is correct[ATTACH=CONFIG]107206[/ATTACH]
        This looks just like the picture in the TIM&JG as well as my 1970 & 1971 both of which have their original exhaust systems. I would expect 1972 to be the same.
        • Ron G.
          • December 1, 1984
          • 865
          "SOLID LIFTERS MATTER"
          • Leonard M.
            • September 7, 2009
            • 236
            Fred, Your clamps aren't like originals, but are probably the best you can find. I do not think the flat strap clamps are reproduced.
            • Fred H.
              • December 4, 2019
              • 311
              Lenny, as always your advice is greatly appreciated
              Fred Hickey
                • 15599
                Lenny's pictures jogged my memory. I failed to note that the rear clamps, for the chrome extensions, have the flat in the top of the loop on my cars. The flattened part of the loop has a letter on it on my 1970. I don't recall that letter at this time, but the TIM&JG may provide some guidance. I haven't had the 1971 long enough to have inspected that part. You have given me some items to look for on my next visit to it.
                Lenny's picture of the center clamp is not like I have, but since my cars are years earlier all I can say is I have seen that style of clamp before on other cars. It may be a mistake to think that all these clamps have to be exactly the same. Different years and different suppliers may account for slightly different configurations. The style of clamp, guillotine at the back and double connection at the middle, may be all that is required from an engineering point of view. I think it is time for more research.
                  • 6942
                  At one time I think Paragon Corvette use to sell the clamps, they were zinc plated but not sure there were from the factory ?. I put them on my 72.
                  • Fred H.
                    • December 4, 2019
                    • 311
                    I appreciate all the great responses. I have a 2 1/2" exhaust clamp GM 3633481, however it doesn't have the flatten part in the loop. I'm incline to use these for the center connection, I have similar 2" clamps I plan to use for the exhaust tip connection. Hopefully the judging consequences aren'tNOS clamp 1.jpg too sever.
                    Fred Hickey
                    • Ron G.
                      • December 1, 1984
                      • 865
                      Fred,
                      The Center Exhaust clamps top portion I believe is flat and similar in configuration to the ones attaching the exhaust tips. For 70 - 71 The center clamp top part is differently shaped.
                      • Fred H.
                        • December 4, 2019
                        • 311
                        Ron, I'm sure you are correct. Lenny's photos I believe confirm it. As of now I have not been able to resource for the 72 style correct center exhaust clamp, I'm in the process of installing a welded muffler LT1 Corvette Central exhaust system and the center clamps they supply do not have the flatten loop configuration.
                        Fred Hickey
                        • Fred H.
                          • December 4, 2019
                          • 311
                          Hi Edward, in researching exhaust tip clamps (2") it appears Paragon offers the correct flat loop style. thanks for the exhaust tips
                          Fred Hickey
                            • 11643
                            Correct.
                            You may have to change the finish on them, but the configuration is essentially correct.
                              • 15599
                              Lenny's picture of the center clamp is not like I have, but since my cars are years earlier all I can say is I have seen that style of clamp before on other cars. It may be a mistake to think that all these clamps have to be exactly the same. Different years and different suppliers may account for slightly different configurations. The style of clamp, guillotine at the middle and double connection at the back, may be all that is required from an engineering point of view. I think it is time for more research.
                              EDIT: I had the configuration backwards. I have to stop responding while I am at work. Too many distractions.
