Aluminum Powerglide Pan - NCRS Discussion Boards
  • Rick C.
    • March 1, 1986
    • 183
    Can anyone tell me if the pan, which is steel, is natural or painted and if painted, what color? Specifically, for a '62. Also, I'm pretty sure I remember reading that the original pans did not have a drain plug. Can anyone confirm that?
    Thanks!
    Rick
    • 43221
    Re: Aluminum Powerglide Pan
    Thanks!
    Rick
    Rick------
    The pan did not have a drain plug. In fact, I don't know of any Corvette automatic oil pan of the 60's through the 80's that did have a drain plug.
    As far as painted or not goes, I do not think the pans were painted but I'm not 100% sure.
    • Mike E.
      • February 28, 1975
      • 5138
      My experience is that they were natural steel. Leaky pan gaskets generally helped minimize rust. 😀
      • Richard G.
        • July 31, 1984
        • 1715
        Unsure if the Corvette P/G had the same pan as the Chevelles of 1964.
        I am 100% Confident the 1964 Chevelle, Powerglide, had a drain plug in the factory pan .
        And it is unlikely the Corvette had a special pan. However I am a couple years off which doesn't apply to this thread.
        I have included a picture of the underside of a 1962 Corvette automatic and it has the pan drain.
        No documentation if its original or not.
        The pans were natural steel like Mike indicated.
        I believe leaving the plug out was a GM cost saving measure.
        I also know the pan plugs came and went on the 700R4/4L60 transmission.
        Like it depended on the what way the wind was blowing.
        Rick
        • Mark E.
          • April 1, 1993
          • 4544
          My theory is the drain plug was eliminated for two reasons: save cost and discourage the DIYer.
          Aren't aluminum PGs sans paint anywhere- case or pan?
          Mark Edmondson
          Dallas, Texas
          Texas Chapter
          • Rick C.
            • March 1, 1986
            • 183
            Thank you!
            Rick
            • Richard M.
              Super Moderator
              • August 31, 1988
              • 11323
              Close to a '62, our Feb built '63 original 300hp PG pan was natural steel and had a date stamped on the bottom flat area.
              No drain plug there or even needed. (It drained by itself after sitting in the garage. PG Puke Syndrome!) lol.
              • Mark E.
                • April 1, 1993
                • 4544
                Wasn't the front license plate re-positioned to the side on some mid-years when equipped with a big-block and automatic? That's a clean look that should have been standard.
                Mark Edmondson
                Dallas, Texas
                Texas Chapter
                  • 43221
                  Mark-------
                  Yes, 66 and 67 big blocks with C-60 and Powerglide had the "offset" front license bracket. However, at least in my opinion, it did not result in a cleaner appearance. I have always considered that it appeared unbalanced, sort of like the way that single exhaust looks on a car.
                  • Paul D.
                    • September 30, 1996
                    • 491
                    I was told once that the plug was eliminated to discourage changing the fluid without changing the filter. Without a drain, trans service is such a messy job for the average DIYer that I'm sure many just skip it.
                      • 43221
                      Paul------
                      I have always believed that is exactly the reason the drain plug was eliminated.
                      • Don H.
                        • December 1, 1981
                        • 1487
                        My 1965 powerglide has the drain plug. Don H.
                          • 43221
                          Yes, I did some more checking and 1964-67 Powerglides had a drain plug.
                          • Leonard M.
                            • September 7, 2009
                            • 236
                            Here's my original 1967 Camaro 327ci 210HP with the original stamped powerglide pan with drain. Did 67 Corvettes have a stamp on the pan? The stamp on this car is T7C 27N = T Toledo Powerglide, 7 1967, C 27 March 27th, N nightshift.
                            • Francis F.
                              • April 1, 1978
                              • 420
                              My 66 PG COUPE 23,xxx Ser # has a drain plug and is natural / no paint finish.Francis
