107 Coil - NCRS Discussion Boards
107 Coil
  • Mark S.
    • July 31, 1983
    • 662
    107 Coil
    Are there any 107 coils out there that the major vendors have discontinued? I could use one for my low horse 61 FI. Thanks! Mark
  • Mike M.
    • May 31, 1974
    • 8400
    Re: 107 Coil
    the most difficult to find delco coil ever. i thought that the chines copy was available, but they done live very long. good luck, mike
    • Mark S.
      • July 31, 1983
      • 662
      Re: 107 Coil
      Thanks Mike! I know that a real one is like chasing down hen's teeth; however, there have been reproductions out there; and I was trying to get lucky with one of those for the time being. Mark
      • G B.
        • December 1, 1974
        • 1407
        Re: 107 Coil
        I have several* new Chinese "Delco" 107 coils still in the box. They are not as strong or long-lived as I would like, but they do usually work to 5,000 rpm for 5 or more years. They then can't re-start the engine when hot. However, they will still start it cold after failing hot and keep the engine running until shut off. Weird.
        * All gone. I had five and they were sold this afternoon.
        • Jimmy G.
          • November 1, 1979
          • 977
          Re: 107 Coil
          Jerry
          You may be OK as this is not the Corvette Forum
          • G B.
            • December 1, 1974
            • 1407
            Re: 107 Coil
            The local landfill won't accept my "commercial" car parts either. I think the CorvetteForum may have tipped them off that I used to have a business.
            • John D.
              • December 1, 1979
              • 5507
              Re: 107 Coil
              The repro won't pass judging anyhow according to what Dr. Mike told me. One thing he pointed out to me was the repro threaded studs are magnetic. Also the location of the 107 12 Volt was another reason. Right Doc???
              Mark, Take advantage of the the Judging reference manual. Just use a known good DR coil and only get a minor deduct.
              • Mike M.
                • May 31, 1974
                • 8400
                Re: 107 Coil
                john: u got it bass-akwards. the repo studs are not magnetic, ie, they are of stainless composition. real studs hold a magnet. mike
                • Mark S.
                  • July 31, 1983
                  • 662
                  Re: 107 Coil
                  Mike:
                  I was aware of that. You had mentioned that to my good friend Dave Cloutier. I was just interested in getting a base line for my own knowledge.
                  John:
                  Jerry Bramlett recommended a Standard Ignition Coil UC12X for compatibility of a 107 in performance.
                  Sincerely,
                  Mark
                  PS: I understand that it 109 degrees in PS today.
                  • John D.
                    • December 1, 1979
                    • 5507
                    Re: 107 Coil
                    Thanks Dr, Mike,. Was a typo and as I know the bit about the studs. Thanks.
                    • Gerald A.
                      • April 30, 1997
                      • 45
                      Re: 107 Coil
                      I have looked for months and just decided to go with 091 coil for my 59 low horse fuelie
                      • John D.
                        • December 1, 1979
                        • 5507
                        Re: 107 Coil
                        Gerald, If it were my car I would do the same as you. Now the 091 for your car isn't cheap but 107's are extinct.
                        I tell people exactly what Jerry Bramlett recommends. Even though the coil is made south of the border it's an excellent one to use except for judging. Joh
                          • 43246
                          Re: 107 Coil
                          John-------
                          From what I can determine, the GM #1115107 coil was never available in SERVICE and was a PRODUCTION-only part number. If so, it's not surprising that this coil would be difficult to find. An NOS example would be, by definition, impossible. Used or reproduction would be the only way to obtain one. By now, the used examples might be mostly "used up".
                          • Gary C.
                            Administrator
                            • October 1, 1982
                            • 17768
                            Re: 107 Coil
                            Once up a time some vendor produced the 107 coil case that would slip over another coil. Gary Pronesti might know who it was or possibly have one.
                            Gary
                            NCRS Texas Chapter
                            https://www.ncrstexas.org/
                            • Dan H.
                              • July 31, 1977
                              • 1369
                              Re: 107 Coil
                              Bob Connors made coil covers long time ago.
                              1964 Red FI Coupe, DUNTOV '09
