1963 Muffler Blackout - NCRS Discussion Boards
  • Danny P.
    • June 30, 2002
    • 344
    Re: 1963 Muffler Blackout
    Originally posted by Greg Barr (29485)
    Thanks for every ones input. I'm going to go with the minimum amount. Greg
    Some years they went crazy with the muffler blackout , over spray everywhere 91.jpg
    • Jack M.
      • March 1, 1991
      • 1195
      Originally posted by Danny Pantuso (63794)
      Some years they went crazy with the muffler blackout , over spray everywhere [ATTACH=CONFIG]107012[/ATTACH]
      Thatz from the 9-28-65 assembly line body drop, for a 66 coupe.
      • Hank D.
        • January 1, 1999
        • 138
        #18
        https://www.forums.ncrs.org/showthre...FLERS-BLACK%3F
        https://www.forums.ncrs.org/showthre...ckout&uid=3414
        • Michael G.
          • November 12, 2008
          • 2158
          #19
          I’ve created a mask/template with this critical drip pattern cut in it for those of you who must be dead nuts accurate in duplicating this entirely random occurrence. Please send a check for $11,457 to Mike, the Somali Prince, Rural Route 23, Bozark, AK. Expect your left and right hand templates (they are actually the same, but don’t tell anybody) and lots of masking tape sometime in the late Fall, depending entirely on how the glacier melt progresses….
          Why is there some sort of rod coming out of the exhaust pipe?
          Mike
          1965 Black Ext / Silver Int. Coupe, L84 Duntov, French Lick, 2023 - Triple Diamond
          1965 Red Ext / White & Red Int. Conv. - 327/250 AC Regional Top Flight.
          • Harry S.
            • July 31, 2002
            • 5344
            #20
            That rod is to keep the exhaust pipes aligned so when the tips are installed they are centered, or close to centered, in the opening on the valance.
            • Michael G.
              • November 12, 2008
              • 2158
              #21
              Thanks Harry
              Mike
              • Michael J.
                • January 27, 2009
                • 7167
                #22
                My restorer uses a version of that rod when doing body off restorations on C2s.
                • Harry S.
                  • July 31, 2002
                  • 5344
                  #23
                  Mike, also (received this today)...
                  From John Hickley presentations the bracket holding the mufflers was used to pull the mufflers inward so body could drop passed the mufflers, ie Body Drop. Must assume the rear valance was attached later after the bracket was removed. If you notice the rear fenders at the valance have some small cutouts, again to aid with body drop.
                  • Tom R.
                    • June 30, 1993
                    • 4102
                    #24
                    Tom Russo
                    78 SA NCRS 5 Star Bowtie
                    78 Pace Car L82 M21
                    00 MY/TR/Conv
