C1 Steering Wheel and Instrument Cluster - NCRS Discussion Boards
  • Tony M.
    • August 31, 2010
    • 102
    I hope everyone is well!
    I know this has been covered before, but what gloss finish would the steering wheel and instrument cluster be painted on a black interior 1959?
    Thanks and have a safe and wonderful 4th of July weekend!
    Tony
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11370
    Re: C1 Steering Wheel and Instrument Cluster
    Tony,
    Steering wheel was a molded-in color, somewhat glossy with usage. I've seen a few NOS examples, all over-the-counter wheels were satin black and had to be painted interior color.
    When I restore a wheel, I use Scotchbrite strips to get the grippers clean, wipe with acetone which gives it a stickier clean surface, then I use a red primer, overnight cure, then a gray sealer, overnight cure again.
    Then top coat with lacquer, about 6 coats with about 2 minutes flash time between coats. I leave it unbuffed when cured. I try not to touch it for several days.
    All clusters were simply unbuffed lacquer like all other interior parts, I.e. radio console, kick panels, heater cover, package tray, etc.
    Rich
    • Tony M.
      • August 31, 2010
      • 102
      Richard,
      This was probably discussed many times in the past but you took the time and gave me a detailed response. You are the best!
      Enjoy this long awaited weekend with family and friends!
      Go Italy!
      Tony
