I hope you and your loved ones are well!
I finally hooked up my Tachometer mechanism by connecting the drive cable to my generator. The tachometer is making load noises and the vibrations could be felt in the steering wheel. The tachometer needle oscillates continuously. The existing drive cable moves freely since I could easily move it from the generator side. I also noticed the tachometer become more stable when I played with the cable from under the dash.
Question: With all that noise, could it be a tachometer or a cable issue. The cable is the original.
Thanks again for all your support!
Tony
Tony
