Greetings.
I'm in need of replacing the front lower control arm (A arm) bushings. The upper A arms are a snap to restore, obviously. The lower A arms.....not so much. I'm having a real struggle getting my spring compressor up inside the spring as the opening in the A arm is quite small but, although I've done this on a '68 I owned many years ago, a bigger problem is manipulating the compressor parts once they are inside the coil. I've read on this forum, I believe, that someone has used a threaded rod in place of the rod/bolt of a standard spring compressor, and one of the "finger hooks" of the compressor. I would not attempt this with a hardware store "all thread" and hence I've purchased an ASTM Grade B7 threaded rod. The B7 spec puts the tensile strength (125,00 psi) about mid point between the SAE Grade 5 and Grade 8 specs. I'm confident that this B7 material would be adequate but I'm still acting on the side of caution--coil springs, obviously, store a huge amount of energy.
The thread on the forum stated, as I recall, to pass the threaded rod up through the spring and through the hole for the upper shock mount--attached with an ASTM Grade B7 washer and nut. The lower leverage point is to attach one of the two "finger hooks" of the standard spring compressor to the lower portion inside of the coil spring. So.........here's the question: The upper A arm attachment point and the upper shock mount area of the front cross member are not under anywhere near the stress that the frame spring pocket and lower A arm pocket are--hence,will the welds attaching the three legs of the outer end of the cross member to the top of the frame stand the necessary force. More simply stated, is this a safe attachment point to use to compress the spring?
Thanks for the help.
