Engine thermostat - NCRS Discussion Boards
Engine thermostat
  • Jack J.
    • July 31, 2000
    • 640
    Engine thermostat
    A friend mentioned a Fail-Safe thermostat. Your thoughts on the idea? Would be rated for 160 Degrees. Thanks Jack J.
  • Ed S.
    • August 6, 2014
    • 1390
    Re: Engine thermostat
    Not familiar with a truly "fail safe" thermostat. That would be quite a feat if it could be done. That said, there is one on the market that will only fail in the open position - apparently the standard or at least most thermostats fail in the closed position. The benefit is quite obvious.
    They are sold under the brand name of "FlowKooler" - I think Summit carries them. And, you can get them in a number of temp ranges - I got a 180 for my '64.
    Ed
    • Keith B.
      • September 15, 2014
      • 1604
      you know a stant brand standard 180 will last a very long time on a pleasure car that is not driven often. I see zero benefit of paying no more then you have too
      • Jack J.
        • July 31, 2000
        • 640
