Main leaf rear spring 1959 C1 - NCRS Discussion Boards
    Infrequent User
    • December 15, 2019
    • 14
    Dear Friends,
    Trying to curl the main leaf of the rear spring with a hand press, I split one.
    Do you think it's possible to find another one with a groove?
    Thank you for your help.
    Patrick
  • Mark S.
    • July 31, 1983
    • 669
    Re: Main leaf rear spring 1959 C1
    Yes, there are others out there with the groove!
    • Terry D.
      • May 31, 1987
      • 2698
      Probably not too many in France, just curious were you heating the spring when bending it?
        Infrequent User
        • December 15, 2019
        • 14
        Dear Terry,
        I gave the leaves to a painter for sanblasting and epoxy and when I read the forum about rear springs, I have learned it was possible to bend the leaves. I try to do that without heating to avoid epoxy damage and obtain a good result for 3 leaves but a disaster for one!20210524_225126.jpg20210524_225150.jpg
        • Richard M.
          Super Moderator
          • August 31, 1988
          • 11370
          Patrick, Where is the split or break?
          Based on your lower photo, the wear on that leaf from its adjoining leaf is extreme. Did it split there?
            Infrequent User
            • December 15, 2019
            • 14
            Richard,
            The main split is at 24cm and the 2 others more distal at 10cm20210526_212053.jpg20210526_212111.jpg20210526_212121.jpg20210526_212129.jpg and the leaf is still twisted.
            The first 3 was correct with 4 ton of pressure and this one broke at 2! (on the hand press)
            • Richard M.
              Super Moderator
              • August 31, 1988
              • 11370
              Patrick, I see much porosity under the epoxy coating. I'm afraid those were not good candidates for cold press re-arcing like I've done in the past.
              And a closer look tells me as I thought... Near that thin worn area from the other spring.
              Do you have photos before the coating? A moot point at this time but it may help understand why they cracked.
              PS let me check around to help you find a replacement. I know you're far away but maybe we can help over here.
              • Gary C.
                Administrator
                • October 1, 1982
                • 17971
                Patrick,
                Suggest you might want to contact Rob in the Dutch Chapter https://www.ncrs.nl/?nlanguage=UK or Tom in the UK Chapter http://www.ncrsuk.com/ to see if they know of anyone that might have a C1 spring.
                Gary
                NCRS Texas Chapter
                https://www.ncrstexas.org/
                • Richard M.
                  Super Moderator
                  • August 31, 1988
                  • 11370
                  Good idea Gary.
                    Infrequent User
                    • December 15, 2019
                    • 14
                    Rich,
                    Thank you for your reply: unfortunately, I've no photo before coating.
                    If you find a main leaf, thank you for telling me.
                    Have a good WE
                      Infrequent User
                      • December 15, 2019
                      • 14
                      Ok Gary: I'll contact Rob and Tom.
                      Thank you again
