Main leaf rear spring 1959 C1 - NCRS Discussion Boards
    Infrequent User
    • December 15, 2019
    • 14
    Dear Friends,
    Trying to curl the main leaf of the rear spring with a hand press, I split one.
    Do you think it's possible to find another one with a groove?
    Thank you for your help.
    Patrick
  • Mark S.
    • July 31, 1983
    • 664
    Re: Main leaf rear spring 1959 C1
    Yes, there are others out there with the groove!
    • Terry D.
      • May 31, 1987
      • 2696
      Probably not too many in France, just curious were you heating the spring when bending it?
        Infrequent User
        • December 15, 2019
        • 14
        Dear Terry,
        I gave the leaves to a painter for sanblasting and epoxy and when I read the forum about rear springs, I have learned it was possible to bend the leaves. I try to do that without heating to avoid epoxy damage and obtain a good result for 3 leaves but a disaster for one!20210524_225126.jpg20210524_225150.jpg
        • Richard M.
          Super Moderator
          • August 31, 1988
          • 11345
          Patrick, Where is the split or break?
          Based on your lower photo, the wear on that leaf from its adjoining leaf is extreme. Did it split there?
          Rich
            Infrequent User
            • December 15, 2019
            • 14
            Richard,
            The main split is at 24cm and the 2 others more distal at 10cm20210526_212053.jpg20210526_212111.jpg20210526_212121.jpg20210526_212129.jpg and the leaf is still twisted.
            The first 3 was correct with 4 ton of pressure and this one broke at 2! (on the hand press)
            • Richard M.
              Super Moderator
              • August 31, 1988
              • 11345
              Patrick, I see much porosity under the epoxy coating. I'm afraid those were not good candidates for cold press re-arcing like I've done in the past.
              And a closer look tells me as I thought... Near that thin worn area from the other spring.
              Do you have photos before the coating? A moot point at this time but it may help understand why they cracked.
              Rich
              PS let me check around to help you find a replacement. I know you're far away but maybe we can help over here.
              • Gary C.
                Administrator
                • October 1, 1982
                • 17774
                Patrick,
                Suggest you might want to contact Rob in the Dutch Chapter https://www.ncrs.nl/?nlanguage=UK or Tom in the UK Chapter http://www.ncrsuk.com/ to see if they know of anyone that might have a C1 spring.
                Gary
                NCRS Texas Chapter
                https://www.ncrstexas.org/
                • Richard M.
                  Super Moderator
                  • August 31, 1988
                  • 11345
                  Good idea Gary.
                    Infrequent User
                    • December 15, 2019
                    • 14
                    Rich,
                    Thank you for your reply: unfortunately, I've no photo before coating.
                    If you find a main leaf, thank you for telling me.
                    Have a good WE
                      Infrequent User
                      • December 15, 2019
                      • 14
                      Ok Gary: I'll contact Rob and Tom.
                      Thank you again
