Clamp riveted to drivers side hood rail - NCRS Discussion Boards
  • Joseph A.
    • June 20, 2012
    • 136
    I have a 69 Corvette and the clamp that holds the washer system hoses that mounts about 10 inches forward of the firewall on the drivers side under hood rail fell off. I have an NOS clamp but I was wondering what type of rivet was used an if it was inserted from the top or bottom of the hood rail. If anyone has a picture that would help.
    • 43221
    Re: Clamp riveted to drivers side hood rail
    Joseph------
    It appears to be a round-headed aluminum rivet and it is definitely installed from the top. It appears to have been set in a rather unusual manner in that the post is not flattened but rather "split" in a "V"-like configuration.
    It was supposed to be GM #3828548 which I cannot find was ever available in SERVICE. However, GM #3828548 was a flat head aluminum rivet and the rivet in question was definitely not a flat head rivet.
    • Joseph A.
      • June 20, 2012
      • 136
      Once again, thank you Joe
      • Joseph A.
        • June 20, 2012
        • 136
        Joe
        Do you know if the rivet was painted body color, I would think not since it is added in the AIM but I would like your opinion.
        • Gary B.
          • February 1, 1997
          • 7024
            • 43221
            Joe
            Joseph------
            My car has been re-painted and the rivet is painted. However, my distinct recollection is that the rivet was originally painted, as well. I have absolutely no recollection of a bare aluminum rivet at that location.
            • Ron G.
              • December 1, 1984
              • 865
              I think I know what you are speaking of, but just to be sure can someone post a pic. If it is the rivet I believe it is, then it is definitely painted. Thanks.
              "SOLID LIFTERS MATTER"
                • 43221
                Ron------
                • Ron G.
                  • December 1, 1984
                  • 865
                  Thanks Joe. However, my 71 has a rivet on the vertical portion of the driver side hood ledge. In a little while I will go and check it to be sure.
                  - Ron
                    • 43221
                    - Ron
                    Ron------
                    I believe 1969 was the last year for the configuration I pictured. I think 1970+ went to the vertical mount as you describe.
                    • Jeffrey S.
                      • May 31, 1988
                      • 1882
                      here is a photo of my Oct 68 69. This was never removed. Hope this helps.
                      Jeff
                      • Dennis D.
                        • March 1, 2000
                        • 1071
                        Ron------
                        Had a discussion last year about an extra hole on the left fender.
                        It would seem most 70 in that thread had the bracket/rivet mounted on the horizontal surface with the "phantom hole" on the vertical surface. In reading through this thread there is mention of 71 having the hole/rivet on the vertical surface. We weren't able to determine why this hole was there on the 70 model. Perhaps the answer may be in the relocation of the hole for 71.
                        https://www.forums.ncrs.org/showthre...in-fender-rail
