1972 Clock not operating - NCRS Discussion Boards
  • Fred H.
    • December 4, 2019
    • 311
    20210506_125404_HDR.jpgThe original clock on my 1972 isn't working. I have researched and followed the instructions on how to disassemble and attempt to resurrect it. The contacts look good and it makes a pop when you energize it but the spring is completely unwound. What are the thoughts on having it repaired or just buying a new replacement?
    Fred Hickey
    Care taker of Top Flight 72 LT1 C60 Convertible #26756
  • Stephen L.
    • May 31, 1984
    • 3159
    Re: 1972 Clock not operating
    If you are worried about judging the new clocks are solid state and don't have the rewind "click".
    I recently purchased a new clock for my '72 Monte Carlo. It is solid state but the second hand works as the original stopping at each second rather than a continuous sweep movement. I believe the clock "mechanics" for a Corvette and a Monte Carlo would be the same with different faces and mounting.......
      • 11653
      You can still buy a brand new clock from Instrument Services Inc made from the original tooling.
      The down side? They changed their paint, and the black is duller than originals. If you know what you're looking for you can see it.
      Otherwise I'd just have your original restored.
      • Fred H.
        • December 4, 2019
        • 311
        Hi Patrick, what is the NCRS point consequences for a quartz replacement clock?
        Fred Hickey
        • Fred H.
          • December 4, 2019
          • 311
          your input is appreciated
          Fred Hickey
            • 11653
            You could lose Operations points, and definitely not pass a PV.
            If judging is in your future, I wouldn't go with quartz.
            • Fred H.
              • December 4, 2019
              • 311
              Hi Patrick, I was able to procure a NOS clock from a fellow NCRS member for a fair price. Now installed and keeping correct time.
              Fred Hickey
                • 11653
                Excellent!
