Correct 1969 Gas Cap - NCRS Discussion Boards
  • Joseph A.
    • June 20, 2012
    • 136
    Below are 2 pictures of the gas cap on my 1969 427/435 Corvette. I am not sure about the drilled holes does anyone know about this?
    • 43221
    Re: Correct 1969 Gas Cap
    Joseph------
    The cap is correct but the holes are not. This cap has an integral pressure/vacuum valve as it should. Someone must have decided this was not enough for them and added the holes. The only Corvette cap that ever had a hole (although not in the location seen here) was the 1963 cap. The 1963 cap did not have the integral pressure vacuum valve.
    • Joseph A.
      • June 20, 2012
      • 136
      Thank you.
      • Daniel S.
        • January 14, 2011
        • 307
        PM sent!
        Dan
