AC Fuel Filter - ID - NCRS Discussion Boards
AC Fuel Filter - ID
  • Loren L.
    • April 30, 1976
    • 4104
    AC Fuel Filter - ID
    Sorry, no picture. Bowl Assembly in a line. Aligned with "IN" and "OUT" as the N/S poles, "OUT" would be printed upside-down and be NORTH; "IN" would be right-side up and be SOUTH; 1/4 tall embossed "AC" in the center; NE quadrant has "MADE IN U.S.A."; NW quad has "PAT. NOS."; SW has "1,705,042"; SE has "2,159,196". Glass bowl has "A" and "C". Filter missing. Appears to be 5/16" fine IN and OUT holes. What is it? Thanks.
  • David B.
    • March 1, 1980
    • 689
    Re: AC Fuel Filter - ID
    Loren, Without doing a lot of checking you seem to be describing the 56-57 dome AC Gasoline Strainer Assembly. Not sure if the 5/16 fine IN and OUT holes are OK. Have info somewhere.
    • Joe R.
      • July 31, 1976
      • 4551
      Loren,
      Here is a pic of some filters. Is this what you are describing?
      JR
      • Mark F.
        • July 31, 1998
        • 1571
        and it looks like the newer patent # was about to expire mid-'56
        thx,
        Mark
        • Loren L.
          • April 30, 1976
          • 4104
          Joe, after conceding your status as a "hoarder", yes. I guess I'm wondering whether Mark's patent info provides a clue, as well as the 5/16" vs. 3/8" lines. Trying to find out for a friend who "risked" $5 at a garage sale............. Thanks.
          • Tom E.
            • June 1, 2019
            • 448
            Joe,
            That filter is identical to the fuel filter on my 1924 Chevy! Want to let go of one of them? LOL you shouldn't miss one!
            • Loren L.
              • April 30, 1976
              • 4104
              Okay, where are the guys with the early '56s with the 5/16" fuel lines..............
              • David B.
                • March 1, 1980
                • 689
                Still having a little problem with your described 5/16 fine IN/OUT holes. You are correct re: early 56 5/16 fuel line however if that fuel filter with 5/16 holes was used, by adding the brass fitting to attach that line it would seem the fuel restriction would become even greater.
                • Loren L.
                  • April 30, 1976
                  • 4104
                  Cursed Fittings!!! Thanks, Dave. maybe a dead-end after all. That will teach that guy to speculate at garage sales...........
