66 rocker panel fr fender bracket finish - NCRS Discussion Boards
  • Robert P.
    • October 19, 2019
    • 306
    Looking to find out if the little bracket riveted to the bottom of the front fender was painted body color , left natural to rust or maybe painted black . any info would be great
    Bob
  • James W.
    • December 1, 1990
    • 2658
    Re: 66 rocker panel fr fender bracket finish
    Bob,
    Do you know whether the car body was built by AOS or at the St. Louis assembly plant? If it was assembled at AOS, I can't say for sure but they may have been the same yellow/green zinc chromate as the other brackets. If the body was built at St. Louis, they were more than likely black. These brackets were installed on the body prior to the body being painted so they may/can show evidence of evidence of the red oxide primer and body color.
    James
    Bob
    • Robert P.
      • October 19, 2019
      • 306
      it is an AOS body so i guess zinc chromate with some body color over spray will do the trick
      Bob
      • Gary B.
        • February 1, 1997
        • 7024
        https://www.forums.ncrs.org/showthre...olding-bracket
        Gary
        • Robert P.
          • October 19, 2019
          • 306
          Gary, thanks for the link as far as paint or no paint on the back side your thoughts
          Bob
          • Gary B.
            • February 1, 1997
            • 7024
            Bob,
            For my St Louis body, I decided to keep them natural, albeit with a satin clear coat.
            Gary
