Repro Trim ring vs. valve stem - NCRS Discussion Boards
  • Mark E.
    • April 1, 1993
    • 4544
    Re: Repro Trim ring vs. valve stem
    Originally posted by Jeffrey Salz (13182)
    The 69 AIM does not have a PO2 page but the contents are listed as I said above. It calls out the extension specifically for the PO2. The extensions are made by Schrader and are about 7/8" long.
    Jeff
    Peace. I was looking at the 1970 AIM... 1972 may also be different.
    Mark Edmondson
    Dallas, Texas
    Texas Chapter
    • Jeffrey S.
      • May 31, 1988
      • 1882
      Peace right back at you. I also don't have the '72 AIM so it may be different. Your 70 AIM matched my 69.
      Jeff
      • Owen L.
        • September 30, 1991
        • 868
        #18
        From '72 (the only specific PO2 reference I can find is on M299 where options are listed) UPC 10 A1, Note G references optional need for a valve extension:
        • Don L.
          • August 31, 2005
          • 1005
          #19
          [ATTACH=CONFIG]110160[/ATTACH]
          Thanks, Owen. I agree that the extension was used only for "options requiring same" as stated in the '72 AIM. In an effort to help clarify a little more, I've attached a copy of the wheel options form the back of the AIM's OPTION LIST. Other than the menu of tires, (BW? WSW, RWL), the only option I see listed is the PO2 wheel cover.
          I hope this helps.
          Don Lowe
          NCRS #44382
          Carolinas Chapter
          • David B.
            • March 1, 1980
            • 689
            #20
            Grp. 5.875 -- 9417745 Extension tubeless tire valve stem (7/8 OL)
            Plain black plastic Type F extension. Effective length installed from top of valve stem to end is .500 To check for correct finished installation note Design consideration: "To provide adequate clearance space for servicing it is recommended extension protrude beyond wheel cover a minimum of .375 inch for type F".
