67 corvette brakes every thing new poor pedal/ - NCRS Discussion Boards
  • Gerry G.
    • December 1, 2004
    • 35
    useing motive bleeder .when do i bleed the master usesing the bleeders on the master.before I do wheels or after I do wheels
  • Tom E.
    • June 1, 2019
    • 448
    Re: 67 corvette brakes every thing new poor pedal/
    Gerry,
    The master cylinder needs to be bled first, then bleed each caliper. Most people bench bleed the MC before it is installed but you can do it either way.
    Here is a procedure written by Duke Williams on bleeding. This and many other documents and procedures can be found in the restoration document repository
    https://www.forums.ncrs.org/attachme...0&d=1499375205
    Tom
    • Danny P.
      • June 30, 2002
      • 341
      If your only one person ,Bench bleed the Master Cyl. keep master full with fluid at all times, then open all bleeders and let it gravity bleed until air bubbles gone and retightened bleeder.
      • Gerry G.
        • December 1, 2004
        • 35
        Duke williams I read your post on brake bleeding,and I'm going to try it.However there is no mention about the bleeders on the master cylinder Do I try to bleed the master useing them?Do I use them to start the bleeding process,Help me if you can thanks
        • John P.
          • August 31, 2002
          • 215
          Could someone direct me to this repository?
          • Mark F.
            • July 31, 1998
            • 1532
            Hi John,
            It is located at the top of the home TDB page as a "STICKY" Post called Database of Restoration Documents started by Rich Mozzetta...this link should take you there as well....
            https://www.forums.ncrs.org/showthread.php?117966-Database-of-Restoration-Documents
            thx,
            Mark
            • William F.
              • June 9, 2009
              • 1363
              Since each rear brake caliper has 2 bleeders, does it matter whether you bleed the outer or inner of the 2 ?
              • Danny P.
                • June 30, 2002
                • 341
                Always bleed the high's point bleeder on each Calipers, there should be one bleeder, lower ones should have a plug fitting on it.IMG_3360.jpg
                • Mark E.
                  • April 1, 1993
                  • 4553
                  I usually bleed the inner bleeder valve first, but I doubt it really matters.
                  Mark Edmondson
                  Dallas, Texas
                  Texas Chapter
                  • Owen L.
                    • September 30, 1991
                    • 869
                    I usually bleed the outer bleeder valve first, but I doubt it really matters.
                    (It's working on the advice to do the furthest from the master cylinder first.)
                    • Mark E.
                      • April 1, 1993
                      • 4553
                      My method is working on the advice to do the closest from the master cylinder first. 😁
                      Mark Edmondson
                      Dallas, Texas
                      Texas Chapter
                      • Richard M.
                        Super Moderator
                        • August 31, 1988
                        • 11324
                        I do both at the same time...gravity style. 2 clear hoses equal length, connected to a Tee to another hose to a bottle. Both rears and fronts at the same time.
                        Rich
                        • Mike E.
                          • February 28, 1975
                          • 5139
                          Every rear that I have done has two bleeders.
                          Originally posted by Danny Pantuso (63794)
                          Always bleed the high's point bleeder on each Calipers, there should be one bleeder, lower ones should have a plug fitting on it.[ATTACH=CONFIG]105552[/ATTACH]
                          • Danny P.
                            • June 30, 2002
                            • 341
                            My method is working on the advice to do the closest from the master cylinder first. 
                            I Gravity bleed first , then Furthest away from Master first then bleed RR RL FR FL works all the time
