door window felt - NCRS Discussion Boards
door window felt
  • Mel S.
    • August 31, 1992
    • 264
    door window felt
    I am installing new window channel in the door for the rear window run with new liner in my 66 conv.. Two questions:
    1. what kind of adhesive should I use
    2. when installing the liner, is seems to me that you need something the thickness of the glass to use as a "form" so the liner is glued in for a smooth path for the travel of the window.
    Mel
    • 6960
    Re: door window felt
    Mel, I used DAP contact cement from the local Home Depot.I used my finger to smooth out, just know the contact cement dries quickly.and overlap the top about. 1/2 inch.
    • Mike M.
      • May 31, 1974
      • 8409
      after applying contact cement to both the run and the fabric, I use a piece of plywood just a tad thinner than the fabric covered run. cut your plywood before using contact cement. mike mccagh
      • Mel S.
        • August 31, 1992
        • 264
        Thanks very much
        • Mel S.
          • August 31, 1992
          • 264
          Thanks for the input. I was thinking of the same thing just wanted more input
          Mel
