1975 L-48 Convertible GROUND STRAPS - NCRS Discussion Boards
  • Lynn S.
    • May 5, 2016
    • 105
    Page 99 of the TIMJ manual states ...Additional ground straps will also be observed between the right rear fendere to the frame and TWO FRONT MOTOR MOUNTS TO THE BLOCK. Are there really supposed to be TWO straps at the motor mounts to the block? We cannot remember there being more than one and that one is usually to the right (passenger) side mount to block. Please advise which is correct. Thanks
    Lynn Skipper 62393
    1995 LT-1 Polo Green conv. w/ Beige/Beige, Chapter Top Flight
    2018 LT-1 GS conv w/ Kalahari/Black, Heritage pkg, 2LE, 8sp w/ paddles
    1975 L-48 Steel Blue conv, w/ Med Saddle/Med Saddle, 4 spd, C-60 current project.
    • 6950
    Re: 1975 L-48 Convertible GROUND STRAPS
    Lynn, if there was a ground strap attached just look at the frame for a sign that a screw was threaded into frame at sometime. If there was not, the hole will be smooth.
    • Lynn S.
      • May 5, 2016
      • 105
      The 1975 Assembly Manual only has 2 sites illustrated for Ground Straps. #1 is from the frame to the left front windshield/firewall support just in front or the driver's side door. #2 is from the radio antenna mounting plate to the frame above and in front of the left rear wheel. I have gone from front page to the rear page of the AIM an found no reference or illustration about a grounding strap from the engine block to the motor mount. Additionally restoration vendors after checking with several accepted vendors, they all only sell a 2 strap kit for reinstallation. I'm asking because the TIMJ Guide says one strap to each side of the block and to it's corresponding engine mount. Hence the confusion.
      Lynn Skipper 62393
      • Tom R.
        • June 30, 1993
        • 4100
        Lynn
        I'm posting a Ground Straps & Cables addendum page that attempts to clarify the topic you've raised. Understand, the 2nd edition of the 75-77 lacked the research and confirmation process that the yet-to-be-published 3rd edition took on over the past 18 months. This page looks at years 73-77 and I'm asking the revision team to take at look at their cars and confirm their findings with the page posted below. You can help by checking your ground straps and cables and compare to the page.
        Ground Straps and Cables.pdf
        Last edited by Tom R.; March 20, 2021, 05:35 AM. Reason: uploaded revised addendum page
        Tom Russo
        78 SA NCRS 5 Star Bowtie
        78 Pace Car L82 M21
        00 MY/TR/Conv
        • Lynn S.
          • May 5, 2016
          • 105
          Thank you Tom. Have a great day. Lynn
          Lynn Skipper 62393
          • Matt B.
            • August 31, 2001
            • 228
            Tom,
            I only found two wires grounded to the frame. One for the battery and one at the very rear of the frame on the LH side. See photos.
            Matt Beltowski
            Florida Chapter
            Michigan Chapter
            • Jimmy P.
              • June 24, 2014
              • 1696
              Hi Matt,
              You should mention that your car (1977) is a radio delete. Which means you don't have the antenna grounding plate and rear ground strap back there. It would attach to that same spot on the frame. Do you have a ground cable coming off your starter brace to the frame under the right side motor mount?
              Jimmy
              1973 Convertible
              L48,M20,N40
              Mille Miglia Red/Oxblood
              • Matt B.
                • August 31, 2001
                • 228
                Jimmy,
                You are absolutely correct. Here's a photo of the ground cable from the starter brace to the RH side motor mount you mention above.
                And yes I should've mentioned my car is radio delete.
                TTYL
                Matt Beltowski
                Florida Chapter
                Michigan Chapter
                • Lynn S.
                  • May 5, 2016
                  • 105
                  Thanks guys. My car has AM/FM radio and the ground from the radio grounding plate to the frame. In addition to the strap from the body support brace to the frame on the left side, is there supposed to be a strap on either frame engine mount to the block?
                  Lynn Skipper 62393
                  • Tom R.
                    • June 30, 1993
                    • 4100
                    Yes...from the starter brace to the block.
                    Tom Russo
                    78 Pace Car L82 M21
                    00 MY/TR/Conv
                    • Lynn S.
                      • May 5, 2016
                      • 105
                      Thanks Tom. We have that one also, sorry I forgot to include it previously. Thanks to everyone for your replies.
                      Lynn Skipper 62393
