1966 power windows - NCRS Discussion Boards
1966 power windows
  • Paul S.
    • June 30, 1982
    • 359
    1966 power windows
    I can't remember , and i really haven't had many power window midyears. ( dumb question ) does the key need to be "on " for the power windows to work . I currently have the hot wire plugged into the fuse box , so it has power all the time , so the windows operate all the time ,if the key is off or on they go up and down. Is this correct ???
  • Don H.
    Moderator
    • June 16, 2009
    • 2283
    Re: 1966 power windows
    Yes. So long as your battery is hooked up, they function. No key required.
    • Bill M.
      • 1330
      I second that
      • William B.
        • April 30, 1975
        • 944
        Kind of a scary thing, if you would let young children alone in the car. It was changed in 1967
        • Jimmy G.
          • November 1, 1979
          • 977
          Easily changable at Fuse Box to only work with key on however.
          • Paul S.
            • June 30, 1982
            • 359
            Jimmy , how can i change it? I dont think there is a post on the fuse box on a 66 that isn't hot all the time . I'd like to change it if i could
              • 6960
              I maybe wrong but does power window work on a circuit breaker?
              • Jimmy G.
                • November 1, 1979
                • 977
                As best as I remember I tied (spliced) the PW wire into a switched circuit.
                • Paul S.
                  • June 30, 1982
                  • 359
                  Thanks jimmy , i look further into it
