looking for wiper vacuum tee - NCRS Discussion Boards
  • Mark G.
    • January 31, 2007
    • 177
    This is for my 69 but I'm sure other C3 years are the same. Vacuum Tee located near the master cylinder and wiper door vacuum relay. Looks like 1/4 x 1/8 x 1/4.
    Mark
  • Deane M.
    • January 2, 2007
    • 144
    Re: looking for wiper vacuum tee
    Try David Sokolwski in Ca. I got a few from him a little while back. 310-329-5334.
    • Mark G.
      • January 31, 2007
      • 177
      Thanks. I will call him.
      • Francais D.
        • October 8, 2016
        • 94
        I have been looking for the same fitting for a year ,i hope he has two of them
        • Richard G.
          • July 31, 1984
          • 1718
          If you find one, send me the old damaged one.
          I will get it drawn up to see how well it can be printed up.
          Then send it back.
          It's plastic, shouldn't be an issue.
          Rick
          • Mark G.
            • January 31, 2007
            • 177
            I've already superglued it together just in case I can not find another one. If/when I do, I'll send it to you. Can you also to the Y fitting for the washer pump hoses to the anti drip valve?
            • Owen L.
              • September 30, 1991
              • 895
              My '72 uses one of these on the far passenger side of the firewall for the climate control system - at least I believe it's the same fitting. The only replacement I've found is Doc Rebuild but he's been down since the Covid thing started.
              • Mark G.
                • January 31, 2007
                • 177
                Then send it back.
                Rick
                I found another broken one. I'll need your address and I'll mail it this week.
