1964-1965 327 Engine Harness Lectric Limited VIG6465 Pink vs. Black/Purple Coil Wire - NCRS Discussion Boards
  • Tom D.
    • September 30, 1981
    • 2151
    LL part number VIG6465 (instruction sheet INS8346) shows a "Black/Pink: "R" Terminal attachment at the starter solenoid. This wire routes to and from the COIL (+), on its way to the ballast resistor . I believe this wire should be pink. (In fact, the instruction sheet says "pink" at the coil end.)
    What am I missing here?
    Thanks.
    https://MichiganNCRS.org
    Michigan Chapter
    Tom Dingman
  • Alan D.
    • January 1, 2005
    • 2054
    Re: 1964-1965 327 Engine Harness Lectric Limited VIG6465 Pink vs. Black/Purple Coil W
    64 R to + coil is B/P
    65 R to + coil is P
    Note the 64AIM has the 65 wiring diagram
    • Stewart L.
      • March 1, 1980
      • 356
      I just went through that on my 396 I’m working on. From my research there was a first and second design engine wire harness, the black/pinkwire became pink in the later style harness. My research involved other 396’s but you description sounds similar. I purchased a NOS engine harness that had a pink wire where the black/pink one was plus there was some other wire color changes. Non of the wire diagrams indicate the changes. I did some continuity checks before I installed it and everything checked out. It starts and runs with no smoke or fried wires.
      • Alan D.
        • January 1, 2005
        • 2054
        The change of the wiring diagram occurred on July 14, 1965, so in the middle of a month when 1309 64 cars were being built.
        Then the 65 cars got produced starting in Aug however only 227 were built.
        • Garry B.
          • January 1, 1991
          • 667
          Tom, I had to deal with this on a '64 I had recently had. The '64 is in fact black with pink stripe. One leads through the firewall at the ballast resistor and connects to one of the terminals. A second black and pink leads from the ballast resistor to the coil and then from the coil down to the R terminal on the starter. The prior owner had installed a HEI coil bypassing the ballast resistor. The black and pink wire running from the coil to the starter was totally fried.
          Garry Barnes #18531
          '67 Lynndale Blue Coupe- National TF, BG
          ​'67 Sunfire Yellow Coupe- 4 Star Bowtie,
