63 Fuel injection motor mounts - NCRS Discussion Boards
  • Tom R.
    • June 30, 1993
    • 4100
    Re: 63 Fuel injection motor mounts
    When a broken motor mount occurs and the engine "torques over" lots of bad things can happen. As I mentioned above, damage to the fan, fan shroud, and hood can occur. In addition, when these things occur, they can cause other bad things to occur, including the driver losing control of the car, at least momentarily.
    The question remains...what makes it a locking style? What's the mechanism. All these links only tell the reader the difference between GM style vs aftermarket style.
    Now having said that Dave shared the following:
    Locking mounts have a "T" appendage that prevents catastrophic failure.
    So what does the T do that is not present on a non-locking engine mount? I think, looking at images it is some sort of catch.
    Tom Russo
    78 SA NCRS 5 Star Bowtie
    78 Pace Car L82 M21
    00 MY/TR/Conv
    • Alan D.
      • January 1, 2005
      • 2046
      Notice tab which holds it if broken
      • Dan H.
        • July 31, 1977
        • 1370
        #18
        In 1986 I acquired a one owner 340 HP 63 Coupe with 63K miles on it. When I pulled the engine in 1988 I heard a thud from something falling on the garage floor. It was the LH motor mount which separated at the rubber, the rest was still bolted to engine, no damage but scary to realize how frail the mounts were.
        1964 Red FI Coupe, DUNTOV '09
        • Tom R.
          • June 30, 1993
          • 4100
          #19
          Originally posted by David Houlihan (36425)
          Locking mounts have a "T" appendage that prevents catastrophic failure. See Below - Non-Locking & Locking Style.
          As I understand its functionality: The engine motor bolts to the block with the "T" appendage pointed upward. If the rubber breaks down, then the T slides but caught in the other half of the engine motor that is attached to the frame...avoiding catastrophic failure.
          Tom Russo
          78 Pace Car L82 M21
          00 MY/TR/Conv
            • 43254
            #20
            Tom-----
            That's how it works. The two steel components of the engine mount (frame side and engine side) cannot "go their separate ways" if the rubber separates from either or otherwise breaks.
              • 43254
              #21
              Dan------
              These old non-locking style mounts are "ticking time bombs".
