Is Sealant Recommended on Heat Riser Valve Gasket? - NCRS Discussion Boards
  • Allen N.
    • January 1, 2003
    • 289
    Is sealant recommended on the gasket between the heat riser valve and exhaust manifold? I am working on a 70 big block.
    Allen
  • Leif A.
    • August 31, 1997
    • 3653
    Re: Is Sealart Recommended on Heat Riser Valve Gasket?
    Never heard of any type of sealant on any heat riser valve...small block or big block.
    Leif
    • Owen L.
      • September 30, 1991
      • 891
      You are using the flat, triangular gasket made for the joint, right? The only time I'd use sealant is if the mating parts were particularly pitted such that the sealant was to fill the pits to aid the flat gasket with a tight seal.
      • Mark E.
        • April 1, 1993
        • 4607
        Hi Allen,
        On the few I've installed I didn't use a sealer, and didn't have any problems.
        How's the '70 coming along?
        Mark Edmondson
        Dallas, Texas
        Texas Chapter
        • Allen N.
          • January 1, 2003
          • 289
          Thanks for the replies.
          Mark, it is coming along slowly. I am about done with the chassis and am going to work on the engine compartment next. I am happy how everything looks, but I tend to do a lot research and waiting on parts to arrive. Thanks for asking.
