1975 Convertible with AM/FM Stereo Radio with A/C - NCRS Discussion Boards
  • Lynn S.
    • May 5, 2016
    • 105
    The 1975 Assembly Manual I have gives a general location on the interior firewall for the radio amplifier. The amplifier for a stereo AM/FM is considerably larger than the non-stereo version. But, the assembly manual does not give any measurement guidelines as it does in many other assemblies. Are there any photos showing the ideal/preferred/recommended location for the amplifier for my stereo application? It appears that once installed, that the judging team cannot see the amplifier, but I want to install it in the correct location. There are several holes from previous owners where it could go but since it was not in place when I bought the car (basket parts car), I want to do it correctly. Thanks for your advice, specific dimensions illustration, etc in advance.
    Lynn Skipper 62393
    1995 LT-1 Polo Green conv. w/ Beige/Beige, Chapter Top Flight
    2018 LT-1 GS conv w/ Kalahari/Black, Heritage pkg, 2LE, 8sp w/ paddles
    1975 L-48 Steel Blue conv, w/ Med Saddle/Med Saddle, 4 spd, C-60 current project.
    • 6956
    Re: 1975 Convertible with AM/FM Stereo Radio with A/C
    Lynn can you use the hole locations on the amp. And match up with the holes that are there on firewall I-know my 72 has a AM/FM is mounted on pass side upper firewall.
    • Mark E.
      • April 1, 1993
      • 4607
      Below are photos from a '70 coupe with U79 AM/FM stereo. This radio has two external boxes as shown. I don't know if this is the same as a '75 convertible but let me know if you want different photos or measurements. If the car had a stereo originally, you should be able to locate the mounting holes.
      Mark Edmondson
      Dallas, Texas
      Texas Chapter
      • Guy F.
        • March 1, 2001
        • 318
        Mark, 1970 AM/FM Stereo radios are different than 1975 AM/FM Stereo radios. There is no separate multiplex adapter in 1975 like there was in 1970. The 1975 stereo convector has 2 power transistors.
        Found this pic on the other forum.
        https://www.corvetteforum.com/forums...echometer.html
        Lynn I hope this helps you.
        Guy
        '75 Convertible L-82/M-21 Silver/Silver L
        '73 Coupe L-82/M-20 Med Blue/Black L
        '23 HTC, 3LT, Elkhart Lake Blue/Jet Black red stitched, Z51 with mag ride,
        FEL, 70th wheels, carbon flash roof, nacelles, mirrors, spoiler, full length stripes,
        edge red calipers plus other goodies
        • Lynn S.
          • May 5, 2016
          • 105
          Thanks Guy.
          Lynn Skipper 62393
