1963 #091 coil tab question - NCRS Discussion Boards
  • Gerald C.
    • June 30, 1987
    • 1299
    Is there a source for purchasing the small tab at the top of the original #091 coil. I have one, but one of the tabs is missing as indicated in the attached picture. I'm also looking to get it tested one of these days.
  • Mike E.
    • February 28, 1975
    • 5141
    Re: 1963 #091 coil tab question
    I assume there is a source somewhere for new ones, but many swap meet and junk yard Delco coils from multiple makes and models have them.
    • Gerald C.
      • June 30, 1987
      • 1299
      Thanks Mike, I'll look around
      • Timothy B.
        • April 30, 1983
        • 5194
        Gerold,
        I am not aware of any tests for the coil, just put it on the car and see how it preforms. I bought a used 091 years ago for my 63 and the car would hardly run. Installed a NAPA IC-12 and all is good.
        • Gerald C.
          • June 30, 1987
          • 1299
          Tim
          I have a replacement coil #091 from Delco Remy. I didn't want the deduction of not having the original coil. I just may take the hit.
          Jerry
          • Timothy B.
            • April 30, 1983
            • 5194
            Jerry,
            If it's one of those reproduction coils make sure you carry a spare just in case.
            • Gerald C.
              • June 30, 1987
              • 1299
              Good advice. Thanks
              • John D.
                • December 1, 1979
                • 5507
                Gerald, The original 091's are very scarce and also major bucks.
                The repros won't pass judging a tthe big shows you know.
                Options are this. Use a known good Delco-Remy coil. See the Judging Standards on point deduct. I think it's 50%.
                Or go buy a NOS '087 but remember to change the ballast resistor to suit and also get a deduct. Most important is how the car runs.
                John
