C3 Body drop - NCRS Discussion Boards
C3 Body drop
  • Justin S.
    • July 3, 2013
    • 305
    C3 Body drop
    70 big block 4 speed no A/C. Are there any special steps or tips to take prior to lowering the body on the frame?
  • John S.
    • June 15, 2015
    • 506
    1973 L82 M21 4 Speed, very original and well documented driver/survivor
    NW Chapter Member, 2016 Bend Regional Top Flight
    73/74 TIM&JG 3rd Edition Revision Team Member
    • Justin S.
      • July 3, 2013
      • 305
      Re: C3 Body drop
      Thanks, John. Did your friend have the shifter installed prior to lowering the body?
      • John S.
        • June 15, 2015
        • 506
        • David H.
          • June 30, 2001
          • 1552
          Re: C3 Body drop
          Justin
          Remove distributor cap and set aside.
          Dave
          • Justin S.
            • July 3, 2013
            • 305
            Re: C3 Body drop
            Thanks, Dave.
            • Richard K.
              • April 1, 1988
              • 207
              Re: C3 Body drop
              Justin,
              Many years ago, before the body drop on my '69, someone advised that the entire parking brake system be installed, especially the spring that attaches to a frame crossmember near the center of the car. Once the body drop has been made, the spring can't be installed.
              • David H.
                • June 30, 2001
                • 1552
                Re: C3 Body drop
                Justin
                Was front suspension rebuilt? In particular, your "A-Arms". If so, and you used standard rubber bushings (recommended), then those cross-shaft bolts should be loose and not tightened until your suspension gets a chance to settle. (bumps/short drive)
                Dave
                • Richard G.
                  • July 31, 1984
                  • 1718
                  Re: C3 Body drop
                  The A arm shields need to be installed on the body.
                  The guys that installed the body on my car broke the shifter during the process. Good catch by others in this thread.
                  Be sure the radio grounds are attached at the top.
                  Search "body drop check list". This has been done before.
                  Rick
                  • Justin S.
                    • July 3, 2013
                    • 305
                    Re: C3 Body drop
                    Thanks, David and Rick. I remember reading about leaving the cross shaft bolts loose so I'm good there.
                    The search title didn't yield anything C3 related and I wasn't sure if a lot of the C2 info could apply with my situation
