A Quiz For Our Engine Experts On My 66 L75 Base Engine - NCRS Discussion Boards
  • Larry E.
    • 1702
    On the pictures below are the before(Top) and after(Bottom) changes on my L75 Base Engine 66 Corvette. I made the changes to
    get into compliance with the judging manual. Can you guess what they are? Comments Please and Thanks in advance>>Larry
    Larry
    LT1 in a 1LE -- One of 134
  • Larry E.
    • 1702
    Re: A Quiz For Our Engine Experts On My 66 L75 Base Engine
    Just a point>Don't get fooled by the different shades of color as one day it was cloudy and the next picture was a more sunny day.
    Different Cameras also as the bottom picture has more "pixels" in it. Larry
    Larry
    • Mike E.
      • February 28, 1975
      • 5153
      Rear of alternator is reclocked, for one. Temperature sender wire extended and rerouted.
      • Larry M.
        • December 1, 1986
        • 541
        Larry - sent you a PM.
        • Dave H.
          • August 17, 2010
          • 47
          I'll start...rotated the alternator housing.
          Next.
          • Lawrence M.
            • February 1, 1995
            • 404
            Rerouted the temp sender wire and put french locks and washers on the exhaust manifolds. As a C3 guy that's about all I can see.
            Larry
            2002 Z51 Convertible
            1969 L46 Convertible
            • Don H.
              Moderator
              • June 16, 2009
              • 2283
              what pastor Mike said, and the french locks like C3 Larry said, and you reoriented the wing screws on the spark plug shields to all be the same.
              Am I seeing a double throttle return spring? that won't fly.
                • 6960
                Exhaust manifold looks like the coating was removed. Larry, is red wire on alternator suppose to be pointed downward ? It appears bunched up. The AIM will show position.is your drivers side horizontal ignition shield tang on the outsider shield? appears inboard of the shield.
                • Peter H.
                  • April 1, 1980
                  • 231
                  • Richard M.
                    Super Moderator
                    • August 31, 1988
                    • 11366
                    Don dump that Scotch down the drain and you won't see double. knukknuk
                    ....Seriously though, looks good.
                    Rich
                    • David M.
                      • September 30, 2004
                      • 533
                      Ignition shield nuts clocked at 9-3 vs 12-6...lol
                      • Mark E.
                        • April 1, 1993
                        • 4610
                        Are the tops of the shocks blacked out on C2s?
                        Mark Edmondson
                        Dallas, Texas
                        Texas Chapter
                        • Larry E.
                          • 1702
                          Thanks to all that have responded; very much appreciated. Learned more about my engine that I did not know. Now to Recap:
                          Most of you got the most noticeable things>Alternator is reclocked;temperature sender wire extended and rerouted.Now the wire
                          goes through that front clip on the valve cover. While we are talking about the alternator Ed Johnson mentioned the routing of the
                          Red Wire. In my AIM Page A8 UPC12 it shows the Bat. Term. Cover facing up and Red Wire going up. It looks like my routing is
                          correct. PLEASE CORRECT ME IF I AM WRONG.
                          Yes I have added french locks and washers on the exhaust manifolds as Lawrence Merchantz mentioned.
                          Don Hooper> Saw a
                          double throttle return spring which is correct. I have been looking for a
                          Throttle return spring either GM#3830222 or Dr.Rebuild #3459204 both black in color but can not find as of yet. If you
                          look at the current Driveline under parts wanted you will see my ad. L.I.C. and Paragon Springs do not have the proper
                          tension. IF ANYBODY KNOWS WHERE I CAN FIND AND BUY THE ABOVE PLEASE LET ME KNOW.
                          Ed Johnson also said>
                          The AIM will show position.is your drivers side horizontal ignition shield tang on the outsider shield? appears inboard of the shield. >>I can not tell for sure from my AIM and not sure what "tang" you are talking about. My horizontal shield
                          tabs are on the outside. Picture below is what my engine was modeled after and you will see the tabs are like mine.
                          Yes the manifolds are different even though the casting numbers are the same. The one on the bottom picture where sent to get
                          ceramic coated plus I added "Calyx" over the coating to get the proper color. Comment always welcomed. Picture below that
                          I based my engine on. Thanks again>Larry
                          Larry
                          • Don H.
                            Moderator
                            • June 16, 2009
                            • 2283
                            HaHa Mozzetta!
                            It wasn't the Scotch after all!
                            Thank goodness I didn't dump it down the drain!
                            • Larry E.
                              • 1702
                              Hay Don; Save some of that Scotch for the football games today. I'll be nursing some Brandy! Thanks Again>Larry
                              Larry
