1955 deco clock - NCRS Discussion Boards
1955 deco clock
  • Al M.
    • February 1, 2004
    • 64
    1955 deco clock
    I recently had to disconnect my clock. Upon returning power, it wound fine but will not start running. I looked to see if there was a thread on this but couldn't find one. I thought there was a procedure needed to get the thing running if power is disrupted. Any thoughts? It was rebuilt and worked fine until just this past week.
  • Gary H.
    • June 30, 1980
    • 155
    Re: 1955 deco clock
    I think you need to pull the knurled adjusting knob out, then let it snap back...
    • Al M.
      • February 1, 2004
      • 64
      Re: 1955 deco clock
      Yea, I tried that several times. I also thought I remembered something about needing to wind it forward 12 hours and that didn't work either.
      • Dennis C.
        • June 30, 2002
        • 888
        Re: 1955 deco clock
        Sounds like the contacts froze together. If that's the case the only solution will be to remove the clock and release/clean the contacts.
        • Gary H.
          • June 30, 1980
          • 155
          Re: 1955 deco clock
          Don't take this personally, but do you have power to the clock?
          Things happen...
