1963 L84 Oil Pressure Connection - NCRS Discussion Boards
  • Loren L.
    • April 30, 1976
    • 4104
    Is there a better photo of the oil pressure line connection on a '63 L84 than the one shown on page 105 of the 6th Edition, 1st Printing? Anybody?
  • Mike M.
    • May 31, 1974
    • 8382
    Re: 1963 L84 Oil Pressure Connection
    loren: are u looking for the brass block that feeds the oil press gauge and also feeds the FI distributor? the repos aren't correct. having judged mechanical for the augusta midget for @ 15 years, over half the judged L84 brass blocks are not configured correctly. mike
    • John D.
      • December 1, 1979
      • 5507
      Loren, I have the best repro but it still has a couple of issues.n
      What Dr. Mike is referring to is the "T fitting.
      On the originals you should be able to put a 1/2" wrech on it. Replacement fittings (everywhere) are thicker.
      What issue are you having Loren. I can snail you an print of the components, etc.
      Not easy to install on the Corvette. No room to work.
      My 63 FI car has the incorrect oil line. Does have the original fittings although I do have a leak.
      I need to install the copper plated line.
      By the way I see these copper plated steel lines advertised for '58 to '65. Totally incorrect. Only original for'63 to '65.
      Don Baker and I have proof. John D
      • Loren L.
        • April 30, 1976
        • 4104
        Mike/John - thanks for the responsel Local restorer working on a one-family owned '63 FI found out I had one that had been judged (Bend - 1981) and called. I remembered the discussion but not the details. (Let's see, my middle name is _____ - where the H___ is that driver's license when I need it?) Need a refresher course. See you in April, Mike.
        • Alan D.
          • January 1, 2005
          • 2038
          Member posted "64 L84 History Search" below, although it's a late 64 FI the oil fittings may be the same, ask him for a photo.
          John & Mike can comment on correctness.
          I just added photo's of mine, wait for John & Mike to comment
          • Mike M.
            • May 31, 1974
            • 8382
            as john degregory noted, the original t-blocks take a 1/2" open end wrench, the repos need a 9/16" wrench. without wrenching alans setup , can't be sure but it sure looks original. mike
