62/63 327/300 original harmonic balancer? - NCRS Discussion Boards
  • Joe M.
    • February 1, 2005
    • 590
    Did the 62 327/300 get an early and late version of the harmonic balancer?
    the balancer on my original 62 327/300, May build, is solid, see upper right balancer.
    Did the 63 327/300 use the same balancer as the 62?
    Did the 63 327/300 have an early and late version of the harmonic balancer?
    Images appreciated
    thanks,
    Happy thanksgiving,
    Joe
  • David L.
    • July 31, 1980
    • 3310
    Re: 62/63 327/300 original harmonic balancer?
    Joe,
    Happy Thanksgiving to you as well.
    I have the same 3 balancers in my collection as well as many more balancers.
    This is my research that I had done years ago based on balancers sold over the counter based on my vintage Chevrolet Parts Catalogs and Chevrolet Parts History:
    1958: GM # 3743849 replaced with GM # 3760584 in Jan. 1959
    1959-1961: GM # 3760584 MIX with GM # 3817684 in Feb. 1962
    1962-1964: GM # 3717684 replaced with GM # 3861968 in Nov. 1964
    1965: GM # 3861968 replaced with GM # 3861970 in Nov. 1965
    The 12 holes around the perimeter are for balancing purposes.
    I am not sure when the actual changes took place on the assembly line.
    The balancer in your photo on the upper left is a 1966-1967 balancer.
    Dave
    • Dennis C.
      • 48
      My original 65 300HP built 12/64 is the same as the upper right balancer photo with no holes .
      • Joe M.
        • February 1, 2005
        • 590
        Dave, to clarify, is the upper right balancer 3817684?
        Balancer on the bottom #3861968?
        what does the 584 balancer look like?
        thanks,
        joe
        • David L.
          • July 31, 1980
          • 3310
          thanks,
          joe
          Joe,
          I have about 10 or so 1958-1965 balancers that I have collected in the 1980's and 1990's. Identifying them has always been a mystery. I have 3 balancers that I actually took off salvage yard Chevrolets that had original engines with ​my identification tags. I will posts photos.
          Dave
          • David L.
            • July 31, 1980
            • 3310
            Balancer without the 12 holes around the perimeter from 1964 Chevrolet 283 w/AC (engine stamped "F0225D"). This matches with the 1965 (12/64) 300 HP Corvette balancer that Dennis mentioned.
            Dave
            • David L.
              • July 31, 1980
              • 3310
              Balancer with the 12 holes from a 1958 Chevrolet truck (Intake dated "C2658" or Mar 26, 1958).
              Dave
              • David L.
                • July 31, 1980
                • 3310
                Balancer with 12 holes from 1959 Chevrolet 283 w/P.G. (engine stamped "T520D" or May 20, 1959).
                Dave
