1102043 Generator - NCRS Discussion Boards
1102043 Generator
  • Terry B.
    Infrequent User
    • June 30, 1980
    • 21
    1102043 Generator
    The 56/57 Judging Guide leads me to believe both the front and rear end frames are aluminum (one painted one natural) on the 1102043 generator. Is my understanding correct or is the rear painted end frame made of something other than aluminum? I will be looking to buy one some time soon and would like to avoid a part that is incorrect. Anything else I should watch out for? If it matters the car was built at the end of March 1957. Thank you.
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11363
    Re: 1102043 Generator
    Terry, On all Corvette 1102043 generators the Commutator End frame(rearward, facing firewall) is a cast part(iron) and is painted black. The Drive End frame is aluminum, unique to Corvette, unpainted. The main case was typically semi-gloss black.
    Drive End 1933109
    Commutator End 1934131 This has the provision for the Tach Drive adapter.
    Here is a document describing Corvette generator end frames which should help. Note the spacing between the bearing center and mount center are shorter than the frames used on Pass car and Trucks, etc.
    C1 Correct Generator
    Also a rebuild doc I wrote with more info on the frames
    Rebuild and end frame info
    Rich
    • Terry B.
      Infrequent User
      • June 30, 1980
      • 21
      Rich ... thank you so much. This information will help a lot!
