Oil Drain Bolt - NCRS Discussion Boards
Oil Drain Bolt
  • Jeff P.
    • 799
    Oil Drain Bolt
    I always thought the drain plug was on at paint but I came across this picture. The restorer might have just wanted some touch for a non judged vehicle. Thank you in advance. Jeff 26AB3279-6645-4FBA-BCEB-DFA51CE56893.jpg
    68 L79 Convertible: Triple Black: Work In Progress, Body off. Now on!
    2014 Arctic White Z51 Vert. (Wifes)
  • Keith B.
    • September 15, 2014
    • 1604
    Re: Oil Drain Bolt
    depending on year they where a 7/8 hex head too
    • Jeff P.
      • 799
      Re: Oil Drain Bolt
      Thank you for the response Keith. Mines a 68 SB.
        • 43287
        Re: Oil Drain Bolt
        Jeff------
        All 1968-82 were 9/16" head. Drain plugs were painted with the engine. Original PRODUCTION drain plug was GM #3921988 and was unfinished natural steel. Original SERVICE plug was GM #3923420 and was zinc plated. No GM plug was black phosphate as the one pictured. In any event, it does not matter as the plug is painted with the engine and finish of the plug, thus, becomes "irrelevant".
        By the way, the GM #3923420 was discontinued from SERVICE in April, 1990 and replaced by the GM #3921988, the original PRODUCTION plug which remains available to this day.
        • Jeff P.
          • 799
          Re: Oil Drain Bolt
          Thanks as always Joe.
