Rebuilder for crimped style fuel pumps - NCRS Discussion Boards
  • Greg S.
    • July 31, 1995
    • 243
    Does anyone rebuild the crimped style fuel pumps specifically a 1969 big block pump?
    • 11644
    Re: Rebuilder for crimped style fuel pumps
    Fred Ballard
    28916 Flowerpark Drive
    Canyon Country, Ca. 91387-1801
    661-251-2362
    Call him, as he prefers that to email.
    • Ron G.
      • December 1, 1984
      • 865
      Like Patrick recommended. Fred Ballard is the guy. In fact he has one of my fuel pumps right now. At this time I am waiting for him to complete it and return it dany day.
      "SOLID LIFTERS MATTER"
        • 11644
        He has 6 of mine right now.
        • Tim G.
          • March 1, 1990
          • 1378
          I need to do preventative maintenance on the fuel pump on my '67. It has been on the car since it was put on at the factory.
          • John S.
            • June 15, 2015
            • 505
            1973 L82 M21 4 Speed, very original and well documented driver/survivor
            NW Chapter Member, 2016 Bend Regional Top Flight
            73/74 TIM&JG 3rd Edition Revision Team Member
              • 11644
              Originally posted by John Sigmund (61302)
              I had some trouble finding a correct replacement that worked with my original fuel line, most of the replacements I found had the canister clocked off about 20 degrees counterclockwise.
              If you can find a replacement that isn't assembled incorrectly, let us know.
              I sent Fred a couple of replacement pumps to try and rotate as well, to see if the manufacturing error can be corrected.
              I have no idea why the factory that assembles them can't do it correctly.
              • John S.
                • June 15, 2015
                • 505
                8F742B91-7227-4099-B81A-385052E96BCF.jpgBA4C7D8B-6621-43FC-B707-0379C6041E6C.jpg6E65600B-2161-4D5F-96AB-A01F13F52175.jpg
                • Ron G.
                  • December 1, 1984
                  • 865
                  • John S.
                    • June 15, 2015
                    • 505
                      • 11644
                      John,
                      I suspect you found a "last one on the shelf."
                      As you, I purchased and returned at least 4, with a couple more I didn't return, trying to find a correctly oriented pump.
                      Based on my observation they all come from the same factory. Someone needs to call that factory in China and have them rotate the assembly jig to the correct position. I don't think that until the vast majority of pumps are returned that the US buyer/supplier will "get it."
                      So, I bought some original pumps and sent them to Fred so I have some that will fit in the years to come.
                      • John S.
                        • June 15, 2015
                        • 505
