68 oil pan wire clip - NCRS Discussion Boards
  • Jeff P.
    • 799
    I was told by a fellow member that this clip in the picture should be to the left 1 bolt. Just verifying this before I go to paint. Thanks, JeffF326CAD1-1537-4B3A-815D-30F2BB013436.jpg
    68 L79 Convertible: Triple Black: Work In Progress, Body off. Now on!
    2014 Arctic White Z51 Vert. (Wifes)
  • John S.
    • June 15, 2015
    • 505
    Re: 68 oil pan wire clip
    Jeff, that is correct. The clip should be located more pan bolt over. It should be located at the lowest point of the side shield and the front two plug wires should be contained in the shield as they go up towards the plugs and the top of the motor mount.
    1973 L82 M21 4 Speed, very original and well documented driver/survivor
    NW Chapter Member, 2016 Bend Regional Top Flight
    73/74 TIM&JG 3rd Edition Revision Team Member
    • Jeff P.
      • 799
      Thank you John and Ralph.
        • 15600
        Originally posted by Jeff Pollard (15573)
        I was told by a fellow member that this clip in the picture should be to the left 1 bolt. Just verifying this before I go to paint. Thanks, Jeff[ATTACH=CONFIG]102370[/ATTACH]
        Just to clarify: that spark plug wire clip was installed before paint, so were the distributor shield uprights; but the rest of the ignition shielding as well as the spark plug wires were installed at St Louis long after engine paint.
        • Jeff P.
          • 799
          Thanks for chiming in Terry.
