C2 Interior Paint - NCRS Discussion Boards
C2 Interior Paint
    • December 1, 2005
    • 199
    C2 Interior Paint
    My 1965 coupe restoration is ready for paint. Exterior is Milano Maroon (900 MM) and the interior is White (437 AA). I am in need of recommendations/input on interior paint (white). Limited areas are painted this interior color. Can anyone provide recommendations on paint brand (PPG, Axalta, etc.) and formula? Also, is the interior paint the same as used for interior "dye". Any help will be greatly appreciated.
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11364
    Re: C2 Interior Paint
    Terry, I don't believe PPG still makes lacquer, not sure about Axalta. Unless you can find some old stock. As I recall "dye" is good for softer goods but I have used it for hardgoods before with good results. I prefer lacquer though.
    I have used TCP Global for all of my lacquer needs over the years. Based in California. Note they can't ship to CA residents, but can everywhere else.
    Under Paint & Coatings drop down, then under Automotive Paint, select Auto Color Library, will bring you here....
    Select your cars year and make to search color books Select Year 1950 1951 1952 1953 1954 1955 1956 1957 1958 1959 1960 1961 1962 1963 1964 1965 1966 1967 1968 1969 1970 1971 1972 1973 1974 1975 1976 1977 Online chips are for reference only. Actual color may vary Reset Search
    Looking up 1965 Chevrolet from the drop down menu, pg 2 of the chart shows all Corvette low gloss interior choices, including White. It is their own "Restoration Shop" brand which I've used many times and is very good quality. I've used their red and blue and black with excellent matching and application results. In one case I used their Turqouise for a '59 interior and the match was absolutely perfect.
    Inside that browser page, upper right, select "White", it'll take you to the Acrylic Lacquer page.....
    Restoration Shop Products are manufactured in the USA to the highest automotive industry standards. WARNING: This product can expose you to chemicals which are known to the State of California to cause cancer, birth defects or other reproductive harm. For more information, go to www.P65Warnings.ca.gov.
    There, select PAINT TYPE " Acrylic Lacquer", etc. Enter the Manuf code from the Page 2 info as required, Ditzler in this case. IIRC Chip Formula # can be left blank.
    Also note the bottom of the page for other needs like proper reducer(thinner), etc.
    It may be best to call them if you're unsure about the menus as it can get a bit confusing. They're great over the phone and can answer all of your questions.
    Rich
    PS Prices have gone up quite a bit I see. Yikes!
      • December 1, 2005
      • 199
      Rich, thanks for the information. Very helpful!
      • Ronald L.
        • October 18, 2009
        • 3248
        Depending upon color the lacquer is in abundant supply, you have to know how to find it.
        Example I have the components to make about ten gallons of 974 Rally Red,
        Milano maroon obviously is a different formula, how soon do you need it?
        • Ronald L.
          • October 18, 2009
          • 3248
          We will be talking about the Real Deal PPG-DuPont stuff...
          In fact if you had the DuPont color components, I just happened across about 300 quarts of various colors of Lucite today...
            • December 1, 2005
            • 199
            Ron,
            I am fixed on my exterior color paint (Milano Maroon) and was looking for information on the white interior paint. I think I'm good for now. Thanks for responding.
